Discuss
Dryer FEQ332ESO stoped running
 in
Dryer Repair
Manufature Date 01-10. OK so it just stoped running one day. Yes there is Power going to it, the Breaker
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer FEQ332ESO stoped running
  #1 (permalink)
Old 06-19-2013, 04:25 PM
Junior Member
Mar-Gun is on a distinguished road
Default Dryer FEQ332ESO stoped running
Brand: Frigidaire   Age: 1 - 5 years
Manufature Date 01-10. OK so it just stoped running one day. Yes there is Power going to it, the Breaker is on and I have 220v inside the Unit. The Light comes on inside. Ok so I Ohm'd out the Start Stop Switch and its OK. I have no Heat, and the Motor dose not turn. Whats Up?
  #2 (permalink)
Old 06-20-2013, 05:08 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire FEQ332ES0 Dryer - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodin...134064000e.pdf
You should not have heat unless the motor is running. There is a centrifugal switch on the motor that activates when the motor gets close to operating speed. One of them switches in power to the heating coil.
I would check the thermal limiter (item 36 in the Cabinet/Drum Parts section) next. It should be 0 ohms.
If it is blown:
1. Check/clean your vent system. Tis is the most common cause of it blowing.
2. Check/clean the bower.
3. Disconnect the heating coil and check it for resistance. it should be about 12 ohms. Then check from each heater connector to the frame/case. Both should be infinite ohms. Sometimes a heating coil can short to the frame and then part of it overheats and blows the fuse.
__________________
  #3 (permalink)
Old 07-02-2013, 04:19 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
If it is blown:
You Hit the Nail right on the Head! I got my $7 part today and it back up and running. Forum at its best. Thankyou......
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer & Dryer all in one stoped agitating Rick Lindsey Washer Repair 1 01-18-2012 06:24 PM
dryer stoped heating Jaym1567 Dryer Repair 0 06-03-2011 08:11 AM
GE dryer stoped Raegan Dryer Repair 0 06-22-2010 06:12 PM
dryer jfrigidaireust stoped running wljdds Dryer Repair 0 03-08-2010 10:15 PM
DRYER JUST stoped heating rcb21 Dryer Repair 1 02-23-2009 03:29 PM
