Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Wiring up new dryer motor (http://forum.appliancepartspros.com/dryer-repair/527989-wiring-up-new-dryer-motor.html)
davisgu80 06-13-2013 07:57 PM
I need some help wiring up my new drive motor. Model #10410892
It has a different switch on it for the wiring connections.
I have a Magtag dryer model #LDE8404ACE
The wires to connect are as follows:
Two black wires that connect together
Two yellow wires that connect together
One blue wire
One red wire
One grey wire with a blue jumper
I need to find out which terminals to connect them to on the new unit.
Thank you.
denman 06-14-2013 03:19 AM
I cannot find any info on the given part number.
You could look up your model at AppliancePartsPros, then click on the motor.
A new page will open with info about the replacement motor includes a Q&A section.
I have no way of knowing if this part is the same as the part you have.
davisgu80 06-14-2013 04:24 AM
More info on my dryer drive motor
Part # AP5272724
P/N -W10410892
Model# S58SVEET-7126
Thank you for your quick response, denman
denman 06-14-2013 05:22 AM
Part number: AP5272724
Click on the above picture and a new page will open with more info.
Looks like the motor should have come with a hook up sheet.
Here is a manual. You will have to join the site to be able to download the manual.
http://appliancejunk.com/forums/inde...a=view;down=53
Simon / APP Team 06-14-2013 10:39 AM
Hi.
The motor part #W10410999.
You will want to wire the unit in accordance with the electric wiring rather than the gas. The Yellow will go where it was originally connected to #6, Red wire to #5, gray wire to 1/4" thermal protector tab, Black wire to #2, and blue and white to #1. You may need to put the jumper between 1 and 5.
Simon.
davisgu80 06-15-2013 06:26 AM
When you say to hook gray wire to 1/4" thermal protector tab,
Is that the same as the #2 position on the switch terminals.
Terminal #2 is the far left position on the switch block.
Thank you, Simon
davisgu80 06-15-2013 08:20 PM
I got my dryer back in operation tonight. Your wiring directions were right.
I looked at the manual you suggested and it helped me understand how the
switch operates and the location of the thermal protector tab.
Thanks for your help.
Simon / APP Team 06-16-2013 01:45 AM
That is my pleasure.
Simon.
Simon / APP Team 06-19-2013 05:29 PM
You are welcome.
Simon.
