ford4wd08
#1 Posted : Tuesday, June 11, 2013 9:42:58 AM(UTC)
ford4wd08
I have a may tag that suddenly stopped heating one day. Also I already tried replacing the thermostat down by the heater element with no avail. Any other ideas or things that are likely to fail besides the element itself?
#2 Posted : Tuesday, June 11, 2013 1:25:56 PM(UTC)
Parts for Maytag LDE412 Dryer - AppliancePartsPros.com
First thing to check is the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
dryer won't heat up (Dryer Repair)
by dnell 8/26/2014 7:21:16 PM(UTC)
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 10/2/2013 9:21:16 AM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
by Teresay 6/11/2013 6:40:08 PM(UTC)
frigidaire dryer won't heat up (Dryer Repair)
by wilde1537 5/6/2013 10:27:04 AM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
by d burns 5/17/2012 12:18:14 PM(UTC)
Bosch Dryer won't heat up (Dryer Repair)
by tericribb 3/18/2012 10:05:30 AM(UTC)
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
Dryer won't heat up to dry clothes (Dryer Repair)
by tdeai 7/21/2011 3:55:49 PM(UTC)
by krisr 2/8/2011 2:52:24 PM(UTC)
Heating Element on Roper Dryer won't heat up (Dryer Repair)
by c grass 11/23/2010 5:26:01 AM(UTC)
by WW47 7/29/2010 1:07:03 PM(UTC)
GE Electric Dryer won't heat up (Dryer Repair)
by lizt 12/27/2009 12:07:30 PM(UTC)
