HOLLYTIM
#1 Posted : Tuesday, June 11, 2013 5:41:18 AM(UTC)
HOLLYTIM
My dryer doesn't get hot enough to dry a normal size load of laundry. I have diconnected exhaust hose and let it run. It will set off my smoke detector so I am assuming that it is reaching a hot enough temp to dry clothes. My question now is, does it matter how long the exhaust hose is?
#2 Posted : Tuesday, June 11, 2013 2:18:53 PM(UTC)
Parts for Estate TEDX640PQ0 Dryer - AppliancePartsPros.com
I am not sure why it sets off your fire alarm but it is not a indicator that the unit is getting hot enough. Your temperature control thermostat which is on the blower opens at 155 degrees F and re-closes at 130 degrees F so your vent exhaust temperature should be in that range when you setfor high heat.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
[COLOR="Blue"]My question now is, does it matter how long the exhaust hose is?[/COLOR]
Yes it does.
The longer the more it will restrict the air flow.
Also the type of pipe/vent hose makes a difference. The plastic vents with all the ridges will restrict the flow the most.
HOLLYTIM
#3 Posted : Tuesday, June 11, 2013 3:21:40 PM(UTC)
HOLLYTIM
Originally Posted by: denman Go to Quoted Post
Now try a run.
Yes it does.
Thank You very much.I will buy a shorter hose.
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Dryer heating problem (Dryer Repair)
by Doehr 8/28/2016 10:41:56 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
maytag stacked Dryer heating problem. (Dryer Repair)
by yudule 8/13/2013 10:30:40 AM(UTC)
Need more help with dryer heating problems (Dryer Repair)
by Steves9411 4/12/2013 4:53:45 AM(UTC)
by jeeprunner81 5/6/2011 8:54:00 AM(UTC)
by pecos 1/19/2011 8:15:26 PM(UTC)
kenmore dryer heating problem (Dryer Repair)
by glc4122 10/19/2010 5:54:26 AM(UTC)
by davisroy 11/11/2009 9:01:42 AM(UTC)
Maytag MLE2000AYW dryer heating problem (Dryer Repair)
by jgram 9/4/2009 4:56:48 AM(UTC)
Whirpool dryer heating problem (Dryer Repair)
by windsordan 7/30/2009 7:25:42 AM(UTC)
by RARMSTRONG@ADELPHIA.NET 12/9/2007 2:05:55 PM(UTC)
gas dryer heating problem (Dryer Repair)
by sakks 9/13/2007 10:48:37 AM(UTC)
