Discuss
Help with dryer troubleshooting
 in
Dryer Repair
My dryer is not blowing heat. I've been googling problems, but I have some questions with some details. Everything says
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Help with dryer troubleshooting
  #1 (permalink)
Old 06-10-2013, 09:21 AM
Junior Member
mreves is on a distinguished road
Default Help with dryer troubleshooting
Model Number: TEDS840PQ1   Brand: Estate   Age: More than 10 years
My dryer is not blowing heat. I've been googling problems, but I have some questions with some details. Everything says a dryer has two circuits on the breaker, but mine only has one, big double breaker, so I guess that's good. The lint hose is clear. The heating coils are not heating up when running, but they do have current running through them, confirmed with my handy voltage tester. Literally, hand hand is still tingling! So what would it be with current going to the coils but them not heating up? Thanks.
Related Models
 TEDS840PQ1 29"ELECTRIC DRYER
 TEDX340RW0 29" ELECTRIC DRYER
 TEDX340RW1 29" ELECTRIC DRYER
 TEDX340RW2 29" ELECTRIC DRYER
Whirlpool TEDX540RQ0 29" ELECTRIC DRYER
 TEDX540RQ1 29" ELECTRIC DRYER
 TEDX640EQ0 ELECTRIC DRYER
 TEDX640EQ1 DRYERS
 TEDX640EQ2 ELECTRIC DRYER
 TEDX640JQ0 ELECTRIC DRYER
 TEDX640JQ1 DRYER
 TEDX640JQ2 29"ELECTRIC DRYER
 TEDX640PQ0 29" ELECTRIC DRYER
 TEDX640PQ1 29"ELECTRIC DRYER
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BU4 ELECTRIC RANGE
Tappan TEF242BU5 ELECTRIC RANGE
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF242BW4 ELECTRIC RANGE
Tappan TEF242BW5 ELECTRIC RANGE
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF303BWF RANGE
Tappan TEF303BWG RANGE
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Tappan TEF317BWF ELECTRIC RANGE
Tappan TEF317BWG ELECTRIC RANGE
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FBB ELECTRIC RANGE
Tappan TEF326FBC ELECTRIC RANGE
Tappan TEF326FSA Tappan/range
Tappan TEF326FSB ELECTRIC RANGE
Tappan TEF326FSC ELECTRIC RANGE
Tappan TEF326FSD ELECTRIC RANGE
Tappan TEF326FSE ELECTRIC RANGE
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Tappan TEF351EWD ELECTRIC RANGE
Tappan TEF351EWE ELECTRIC RANGE
Tappan TEF351EWF ELECTRIC RANGE
Tappan TEF351EWG ELECTRIC RANGE
Tappan TEF351EWH ELECTRIC RANGE
Tappan TEF351EWJ TAPPAN/ELECTRIC RANGE
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
Tappan TEF353AQE Tappan/range
  #2 (permalink)
Old 06-10-2013, 10:58 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Estate TEDS840PQ1 Dryer - AppliancePartsPros.com
See the attachment for your wiring diagram
Yes it is probably OK. It should disconnect both sides of the line.
Since you mentioned the breaker has this unit ever worked with this electrical set up.
I would try flipping it off/on slowly. Sometimes you can loose half the line without tripping the breaker.
The coils can have voltage but if they are open no current will flow.
I do not know how much electrical you know so perhaps the foll0owing will help you.
Your hose electrical is actually two 120 volt supplies with a common Neutral but they are 180 degrees out of phase. So when one is at positive 120 volts, the other is at negative 120 volts. You then get 240 volts between the two (l1 to L2).
The heating coils require the full 240 volts as they are not hooked to Neutral.
The shock you received may have been just from 120 volts.
The first thing to do is to make sure the unit is getting 240 volts with a meter. Use a AC voltage scale that is higher than 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If the power is good then you can unplug the unit and use resistance.
This is a much safer way to check things.
The heating coil should be 8 to 12 ohms.
The thermal cutoff, hi-limit thermostat and operating thermostat should all be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #3 (permalink)
Old 06-12-2013, 08:29 AM
Junior Member
Default
So if the coil is getting enough power then what is my problem. The coil just bad? The thermostat bad? Something else.
  #4 (permalink)
Old 06-12-2013, 11:28 AM
Senior Expert
APP Volunteer
Default
If the coil has 240 volts across it and does not heat up then it is bad.
Note that it is easier and safer to check the heating coil with a meter for resistance with the unit unplugged.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer getting hot but won't dry troubleshooting sosoguju Dryer Repair 1 08-31-2012 12:36 PM
Dryer Will Not Start - Need troubleshooting help quickdraw841 Dryer Repair 1 04-04-2011 05:12 PM
Troubleshooting Gas Dryer 213030520 Dryer Repair 1 07-19-2010 03:50 PM
dryer troubleshooting seo Dryer Repair 1 08-02-2009 07:55 AM
Gas Dryer Troubleshooting RICK 3 Dryer Repair 3 04-30-2008 03:18 AM
