Discuss
Dryer turns on when door is closed
 in
Dryer Repair
My dryer turns on every time the door is closed when a drying cycle is not complete. Normally I had
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer turns on when door is closed
  #1 (permalink)
Old 06-09-2013, 05:43 PM
Junior Member
kbharbison is on a distinguished road
Default Dryer turns on when door is closed
Model Number: PYE2300AYW   Brand: Maytag   Age: 5 - 10 years
My dryer turns on every time the door is closed when a drying cycle is not complete. Normally I had to push the knob on the control panel for the dryer to start running again. Now I have to turn the control knob to end the drying cycle every time I want to shut it off before the cycle is done.
I need to know what part has failed and needs replaced.
Thanks!
Related Models
Maytag PYE2300AYW DRYER- ELE
Maytag PYE2300AZW DRYER- ELE
Admiral PYE3200AGW DRYER- ELE
Maytag PYE3200AYW DRYER- ELE
Maytag PYE3200AZW DRYER- ELE
Admiral PYE3300AGW DRYER- ELE
Admiral PYE3300AKW DRYER- ELE
Maytag PYE3300AYW DRYER- ELE
Maytag PYE3300AZW DRYER- ELE
Maytag PYE3360AYW DRYER- ELE
Maytag PYE4500AYQ DRYER- ELE
Maytag PYE4500AYW DRYER- ELE
Maytag PYE4500AZW DRYER- ELE
Maytag PYE4557AYW DRYER- ELE
Maytag PYE4558AYW DRYER- ELE
Maytag PYET244AYW DRYER- ELE
Maytag PYET244AZW DRYER- ELE
Maytag PYET344AYW DRYER- ELE
Maytag PYET344AZW DRYER- ELE
Maytag PYET444AYW DRYER- ELE
Maytag PYET444AZW DRYER- ELE
Maytag PYG1000AWW DRYER- GAS
Maytag PYG2000AWW DRYER- GAS
Maytag PYG2200AWW DRYER- GAS
Admiral PYG2300AGW DRYER- GAS
Maytag PYG2300AWW DRYER- GAS
Maytag PYG3200AWW DRYER- GAS
Maytag PYG3250AWW DRYER- GAS
Maytag PYG3300AWW DRYER- GAS
Maytag PYG3360AWW DRYER- GAS
Maytag PYG4500AWQ DRYER- GAS
Maytag PYG4500AWW DRYER- GAS
Maytag PYG4557AWW DRYER- GAS
Maytag PYG4558AWW DRYER- GAS
Admiral PYGS244AWW DRYER- GAS
Maytag PYGT244AWW DRYER- GAS
Maytag PYGT344AWW DRYER- GAS
Maytag PYGT444AWW DRYER- GAS
Amana QDO-695 RANGE- S/C S/I DDRAFT GAS
Amana QDO-695D RANGE- S/C S/I DDRAFT GAS
Amana QDO-695E RANGE- S/C S/I DDRAFT GAS
Amana QDO-695F RANGE- S/C S/I DDRAFT GAS
Amana QDO-695G RANGE- S/C S/I DDRAFT GAS
Amana QDO-695H RANGE- S/C S/I DDRAFT GAS
Amana QDU-838 RANGE- S/C S/I DDRAFT GAS
Amana QDU-858 RANGE- S/C S/I DDRAFT GAS
Amana QDU-878 RANGE- S/C S/I DDRAFT GAS
Amana QDU-966 RANGE- S/C S/I DDRAFT GAS
Amana QDU-976 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661B RANGE- S/C S/I DDRAFT GAS
Amana QKO-661C RANGE- S/C S/I DDRAFT GAS
Amana QKO-661D RANGE- S/C S/I DDRAFT GAS
Amana QKO-661E RANGE- S/C S/I DDRAFT GAS
Amana QKO-751 RANGE- S/C S/I DDRAFT GAS
Amana QKO-751A RANGE- S/C S/I DDRAFT GAS
Amana QKU-647 RANGE- S/C S/I DDRAFT GAS
Amana QKU-647A RANGE- S/C S/I DDRAFT GAS
Amana QMC811 WALLOVEN- STD MWAVE ELE
Amana QMD-800 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800E MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-810 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD800 WALLOVEN- STD MWAVE ELE
Amana QMD800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD810 WALLOVEN- STD MWAVE ELE
Amana R-1 RANGE- S/C S/I DDRAFT GAS
Amana R-1H RANGE- S/C S/I DDRAFT GAS
Amana R-1J RANGE- S/C S/I DDRAFT GAS
Amana R-1J MWAVE - FAMILY SIZE (60 HZ)
Amana R-2 RANGE- S/C S/I DDRAFT GAS
Amana R-3 RANGE- S/C S/I DDRAFT GAS
Amana R-3 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE- MOUNTED OVER RANGE/WO
Whirlpool R101 Air-conditioner/heat pump
Whirlpool R1011 Air-conditioner/heat pump
Whirlpool R1012 Air-conditioner/heat pump
Whirlpool R1013 AIR CONDITIONER
Whirlpool R1014 AIR CONDITIONER
Whirlpool R121 Air-conditioner/heat pump
Whirlpool R1211 Air-conditioner/heat pump
Whirlpool R1212 AIR CONDITIONER
Whirlpool R1213 AIR CONDITIONER
Whirlpool R1231 Air-conditioner/heat pump
 R1404 Air Conditioner
Whirlpool R141A AIR CONDITIONER
Whirlpool R141A1 AIR CONDITIONER
Whirlpool R141F0 AIR CONDITIONER
Whirlpool R141G0 AIR CONDITIONER
Amana R15 MISC / ACCESSORY
Whirlpool R153 Air-conditioner/heat pump
Amana R15A MISC / ACCESSORY
Amana R15L MISC / ACCESSORY
Amana R15LA MISC / ACCESSORY
Whirlpool R183 AIR CONDITIONER
Whirlpool R183A AIR CONDITIONER
Whirlpool R183A1 AIR CONDITIONER
Whirlpool R183A2 AIR CONDITIONER
Whirlpool R183A3 AIR CONDITIONER
Whirlpool R183F0 AIR CONDITIONER
Whirlpool R183G0 AIR CONDITIONER
Whirlpool R183G1 AIR CONDITIONER
Amana R1E MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air R200 SURFACE UNIT- DDRAFT ELE
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 SURFACE UNIT- DDRAFT ELE
Jenn-Air R201-C SURFACE UNIT- DDRAFT ELE
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
Frigidaire R21CL3 Frg(v4) / Electric Range
Frigidaire R21CL4 Frg(v6) / Electric Range
  #2 (permalink)
Old 06-10-2013, 01:16 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
http://www.appliancepartspros.com/pa...del=PYE2300AYW
Sounds like the push to start switch is bad.
I believe it is part of the timer on this unit.
Check it with a meter.
Looks like it is S to M on the timer.
It should be infinite ohms when not activated.
Be sure to disconnect the wires going to one side of it when measuring it. This prevents you from reading an alternate/parallel circuit path.
Also be sure to unplu the unit before working on it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door won't stay closed - Wires broke that keep door closed 170530 Dryer Repair 0 08-26-2012 09:55 AM
turntable turns when door is closed and no cooking going on ezduzit62 Microwave Repair 0 12-30-2009 11:50 AM
Dryer door won't stay closed jgilje Dryer Repair 1 08-16-2009 05:59 PM
Gas dryer starts when door is closed DonnySchepp Dryer Repair 8 06-22-2008 12:31 PM
Dryer door won't stay closed tquintero Dryer Repair 1 05-01-2008 03:30 PM
