Discuss
Drum Hole Plug - Whirlpool Electric Dryer
 in
Dryer Repair
My dryer stopped spinning, opened it up, belt is broken, have ordered replacement. However, I found a small metal piece
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Drum Hole Plug - Whirlpool Electric Dryer
  #1 (permalink)
Old 06-04-2013, 05:58 AM
Junior Member
Janmoho is on a distinguished road
Default Drum Hole Plug - Whirlpool Electric Dryer
Model Number: LER5620KQ1   Brand: Whirlpool   Age: 5 - 10 years
However, I found a small metal piece laying on the bottom, which I identified from your parts list as a Drum Hole Plug (#24 in Bulkhead, your part # AP3080776).
I don't need to order the part, I just need to know where does it go? On the schematic, it's just up in the air, no indication where it goes.
Any help you can give would be deeply appreciated, because if I can't find out where it goes, I'll be putting the dryer back together without the part - will that cause any trouble down the road?
BTW, I'm a 61 year old woman, unemployed and thanks to your videos, I had the confidence to take apart the dryer and will attempt to repair it myself, so thanks for that!
Regards,
Jan
Related Models
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
Whirlpool LER6634BW0 ELECTRIC DRYER
Whirlpool LER6634BW1 ELECTRIC DRYER
Whirlpool LER6634BW2 ELECTRIC DRYER
Whirlpool LER6634DQ0 ELECTRIC DRYER
Whirlpool LER6634DQ1 ELECTRIC DRYER
Whirlpool LER6634DW0 ELECTRIC DRYER
Whirlpool LER6634DW1 ELECTRIC DRYER
Whirlpool LER6634DZ0 ELECTRIC DRYER
Whirlpool LER6634DZ1 ELECTRIC DRYER
Whirlpool LER6636PW0 29" ELECTRIC DRYER
Whirlpool LER6636PW1 29" ELECTRIC DRYER
Whirlpool LER6638DQ0 ELECTRIC DRYER
Whirlpool LER6638DQ1 ELECTRIC DRYER
Whirlpool LER6638DW0 ELECTRIC DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 5 12-09-2013 06:43 PM
Need help ASAP.... hole created inside drum jhilts1 Dryer Repair 1 02-27-2013 08:02 PM
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? Darrel Hedman Dryer Repair 1 05-13-2011 06:18 PM
Hole blown in outer drum-What caused it? hiker Washer Repair 1 11-26-2010 01:29 PM
Neptune Washer Drum Hole swipter Washer Repair 1 01-27-2009 06:04 AM
