I had to replace Drive motor on my Gas Dryer, now the timer will not advance. the Dryer works fine on all settings. Replaced the Timer and Electronic Control Board, with no luck. I am not getting 115 volts on the two black wires that connect to the timer motor while the Dryer is running. Removed the Timer Motor and connected 115 volts to it and worked. What could be my problem?
