Discuss
GE Dryer Repair. Won't spin or blow air.
 in
Dryer Repair
DESCRIPTION OF PROBLEM: Today, our front-loading GE Dryer DCVH680EJ1WW stopped working properly. It is about 3 years old. It won't
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Dryer Repair. Won't spin or blow air.
  #1 (permalink)
Old 06-02-2013, 06:30 PM
Junior Member
dewittenborn is on a distinguished road
Default GE Dryer Repair. Won't spin or blow air.
Model Number: DCVH680 EJ1WW   Brand: GE   Age: 1 - 5 years
Today, our front-loading GE Dryer DCVH680EJ1WW stopped working properly. It is about 3 years old. It won't spin and it won't blow air into the drum (hot or cold). When turning it on, I hear an electric hum, but no action with air or drum.
TROUBLESHOOTING:
I tried turning the drum by hand and found that there was resistance, indicating the belt was probably okay. I ran the dryer with the door open and could not feel any air blowing into the drum. I ran the dryer with the door closed for about 5 minutes with the heat set to high. When I checked on it, the air was not hot in the dryer and there was a funny burnt plastic smell.
I then took the dryer apart.
The belt was tight around the drum, fed properly through the motor and the idler pulley, and did not look worn or stretched. It did not slip on the drum and when I turned the fan, it slowly turned the drum.
I then used a multimeter to check various parts for continuity (I don't know what all these parts are and here is where I need the most help). The following two thermistors were the only ones that did NOT have continuity (they read infinity on the meter, whereas all the other parts read zero). I copied and pasted the items directly from GE's appliance parts website:
I believe these are the inlet control and outlet controls.
INLET CONTROL THERMISTOR 506 WE4M398 $31.00
THERMISTOR , OUTLET CNTR 240 WE4M336 $70.75
https://www.geapplianceparts.com/GEA...delgroupsearch
The above link has diagrams of these parts because I couldn't copy/paste them into the post.
I also attempted to check the motor, but this was not as straight forward as the thermostats/fuses. I got readings of zero or near zero at all combinations of terminals 6, 7, and 8 (the only terminals with wires going into the motor). The wiring harness also has wires coming in at terminals 1, 3, and 9, but I got all infinities for any combination using these terminals. The important wires (red and brown/yellow) got good ohm readings. Terminals 1, 3, and 9 consist of a ground, a switch, and a black wire (not sure what it does) and only come into the harness and don't follow out into the motor.
MY QUESTIONS:
What do these 2 thermistors do?
I tested continuity on each of them by putting the leads on the two terminals of each individual thermistor (not touching any other items), was this correct?
What are the chances both of these would go out at the same time? If they went out at the same time, does this indicate that something else is the cause?
Do I need to do anything else to troubleshoot the motor?
I understand how the two thermistors could explain why I'm not getting any air blown into the drum. But why isn't the drum turning if the belt looked okay? Is the motor bad too? Can a bad motor make the thermistors blow? What are the chances of blowing two thermistors and a motor?
Thank you for any advise/help!!!
Related Models
General Electric DCVH680EJ0BB ELECTRIC DRYER
General Electric DCVH680EJ0MS ELECTRIC DRYER
General Electric DCVH680EJ0MV ELECTRIC DRYER
General Electric DCVH680EJ0WW ELECTRIC DRYER
General Electric DCVH680EJ1BB ELECTRIC DRYER
General Electric DCVH680EJ1MR ELECTRIC DRYER
General Electric DCVH680EJ1MS ELECTRIC DRYER
General Electric DCVH680EJ1WW ELECTRIC DRYER
General Electric DCVH680EJ2MR ELECTRIC DRYER
General Electric DCVH680GJ0BB GAS DRYER
General Electric DCVH680GJ0MR GAS DRYER
General Electric DCVH680GJ0MS GAS DRYER
General Electric DCVH680GJ0MV GAS DRYER
General Electric DCVH680GJ0WW GAS DRYER
General Electric DCVH680GJ1BB GAS DRYER
General Electric DCVH680GJ1MR GAS DRYER
General Electric DCVH680GJ1MS GAS DRYER
General Electric DCVH680GJ1WW GAS DRYER
General Electric DCVH680GJ2BB GAS DRYER
General Electric DCVH680GJ2MR GAS DRYER
General Electric DCVH680GJ2MS GAS DRYER
General Electric DCVH680GJ2WW GAS DRYER
General Electric DCXR453EV0AA Electric dryer
General Electric DCXR453EV0WW Electric dryer
General Electric DCXR453EV1AA Electric dryer
General Electric DCXR453EV1WW Electric dryer
General Electric DCXR453GV0AA Gas dryer
General Electric DCXR453GV0WW Gas dryer
General Electric DCXR453GV1AA Gas dryer
General Electric DCXR453GV1WW Gas dryer
General Electric DCXR463EA0AA Electric dryer
General Electric DCXR463EA0WW Electric dryer
General Electric DCXR463EA1AA Electric dryer
General Electric DCXR463EA1WW Electric dryer
General Electric DCXR463GA0AA Gas dryer
General Electric DCXR463GA0WW Gas dryer
General Electric DCXR463GA1AA Gas dryer
General Electric DCXR463GA1WW Gas dryer
General Electric DCXR463GA2AA Gas dryer
General Electric DCXR463GA2WW Gas dryer
Maytag DCZ1010 STACKED LAUNDRY- ELE
Maytag DCZ1040 STACKED LAUNDRY- ELE
Maytag DCZ1040AM STACKED LAUNDRY- ELE
Amana DD0820 RANGE- S/C S/I DDRAFT GAS
Amana DD0880 RANGE- S/C S/I DDRAFT GAS
Admiral DDB1501AWB DISHWASHER- UNDERCOUNTER
Admiral DDB1501AWW DISHWASHER- UNDERCOUNTER
Admiral DDB1501AWZ DISHWASHER- UNDERCOUNTER
General Electric DDC0580BBL Electric dryer
General Electric DDC4307VEL Electric dryer
General Electric DDC4397VEL Gas dryer
General Electric DDC4397VFL Gas dryer
General Electric DDC4397VSL Gas dryer
General Electric DDC4400AEL Electric dryer
General Electric DDC4400SAM Electric dryer
General Electric DDC4400SFM Electric dryer
General Electric DDC4400SGM Electric dryer
General Electric DDC4400SHM Electric dryer
General Electric DDC4400SJM Electric dryer
General Electric DDC4400SKMWH Electric dryer
General Electric DDC4400SLMWH Electric dryer
General Electric DDC4400SMMWH Electric dryer
General Electric DDC4400SNMWH Electric dryer
General Electric DDC4400T0WH ELECTRIC DRYER
General Electric DDC4400T1WH ELECTRIC DRYER
General Electric DDC4400T2WH ELECTRIC DRYER
General Electric DDC4400T3WH ELECTRIC COIN-OP DRYER
General Electric DDC4407AEL Electric dryer
General Electric DDC4407AFL Electric dryer
General Electric DDC4407AHL Electric dryer
General Electric DDC4407AJL Electric dryer
General Electric DDC4407AKL Electric dryer
General Electric DDC4408AEL Electric dryer
General Electric DDC4408AFL Electric dryer
General Electric DDC4408AHL Electric dryer
General Electric DDC4408AJL Electric dryer
General Electric DDC4408AKL Electric dryer
General Electric DDC4492ABL Electric dryer
General Electric DDC4492AEL Gas dryer
General Electric DDC4492AFL Gas dryer
General Electric DDC4492AGL Gas dryer
General Electric DDC4497AEL Gas dryer
General Electric DDC4497AFL Gas dryer
General Electric DDC4497AGL Gas dryer
General Electric DDC4497AHL Electric dryer
General Electric DDC4497AJL Gas dryer
General Electric DDC4498AEL COMMERCIAL DRYER
General Electric DDC4498AFL Gas dryer
General Electric DDC4498AGL Gas dryer
General Electric DDC4498AHL Gas dryer
General Electric DDC4498AJL Gas dryer
General Electric DDC4500SAM Gas dryer
General Electric DDC4500SBM Gas dryer
General Electric DDC4500SFM Gas dryer
General Electric DDC4500SGM Gas dryer
General Electric DDC4500SHM Gas dryer
General Electric DDC4500SJM Gas dryer
General Electric DDC4500SKM Gas dryer
General Electric DDC4500SLMWH Gas dryer
General Electric DDC4500SMMWH Gas dryer
General Electric DDC4500SNMWH Gas dryer
General Electric DDC4500SPMWH Gas dryer
General Electric DDC4500SQMWH Gas dryer
General Electric DDC4500T0WH GAS DRYER
General Electric DDC4500T1WH GAS DRYER
General Electric DDC4500T2WH GAS COIN-OP DRYER
General Electric DDC4500T3WH GAS COIN-OP DRYER
General Electric DDC4500T4WH GAS COIN-OP DRYER
General Electric DDC4580BCL Gas dryer
General Electric DDC4580VCL Electric dryer
General Electric DDC5000FAL Electric dryer
General Electric DDC5000FBL Electric dryer
General Electric DDC5000MAL Electric dryer
General Electric DDC5000MBL Electric dryer
General Electric DDC5000MCL Electric dryer
General Electric DDC5000MDL Electric dryer
General Electric DDC5000SBLAD Electric dryer
General Electric DDC5000SBLWH Electric dryer
General Electric DDC5000SCLAD Electric dryer
General Electric DDC5000SCLWH Electric dryer
  #2 (permalink)
Old 06-03-2013, 11:07 PM
Junior Member
Default Fixed
FIXED (I hope).
Tonight, I took everything apart again and put it back together.......aaaaand, it works! I have no idea why it works, but it does.
Which begs the question: what was the cause of the original problem and what changed to fix it? Any guesses?
The two thermistors that did not have continuity were obviously not broken like I originally thought (and after a little research, discovered that a thermistor is a thermal resistor. So since they are resistors that change resistance depending on temperature, my settings on the multimeter were probably too low and it only looked like infinity when it was supposed to be 10,000 ohms or so).
I hope that taking it apart acted like a "reset" and that the problem doesn't pop up again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Element Hot, no Spin No Blow guardiancs Dryer Repair 3 03-17-2013 06:24 PM
Kenmore gas dryer does not blow hot air Tjbarch Dryer Repair 1 02-13-2012 11:04 PM
Dryer doesn't blow hot air tdormonde Dryer Repair 1 04-25-2011 06:13 PM
Dryer will not blow air... darkmelody Dryer Repair 1 11-08-2010 07:43 AM
Maytag Dryer will not blow Duckman21 Dryer Repair 1 04-12-2010 06:29 AM
