Discuss
Replaced Coil, worked 1 load, now no heat, Help
 in
Dryer Repair
Dryer quit heating last week. Opened it up and discovered broken heater element. Ordered heater element kit, remove heater assembly
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replaced Coil, worked 1 load, now no heat, Help
  #1 (permalink)
Old 06-02-2013, 11:34 AM
Junior Member
ref2coach is on a distinguished road
Default Replaced Coil, worked 1 load, now no heat, Help
Model Number: DHSR333EA2WB   Brand: GE   Age: More than 10 years
Dryer quit heating last week. Opened it up and discovered broken heater element. Ordered heater element kit, remove heater assembly and restrung, put dryer back together dried ONE load perfectly. Second load no heat. Opened it back up, coil has continuity. Checked outlet for 220 Volts, good. Noticed a split in pig tail just below the plug. Took it apart and found white wire had arced and broken inside the neck of the plug. Cut back the cord about 8" and rewired the plug. Instead of putting the drum back in and panels on, I decided to test to see if element heats up. Set time to "timed dry", heat selector to high and held start button on. Motor come on running the blower. The heater element does not heat on either medium or high.
Using meter, short side and long side of coil has 119.1 volts if I test from coil to heater assembly, it has a 119.1 volts when holding start switch on. Out of curiosity I tested when motor is not running, it has 119.1 all the time.
Direction on what to test next would be appreciated.
Related Models
General Electric DHSR333EA2WB Electric dryer
General Electric DHSR333EV0WB Electric dryer
General Electric DHSR333EV1WB Electric dryer
General Electric DHSR333EV2WB Electric dryer
General Electric DHSR333GA0WB GAS DRYER
General Electric DHSR333GA1WB Gas dryer
General Electric DHSR333GA2WB Gas dryer
General Electric DHSR333GA3WB Gas dryer
General Electric DHSR333GV0WB Gas dryer
General Electric DHSR333GV1WB Gas dryer
General Electric DHSR333GV2WB Gas dryer
General Electric DHSR333GV3WB Gas dryer
Amana DHU709 WALLOVEN- STD MWAVE ELE
Bosch DHZ8020
Bosch DHZ8060
Bosch DHZ9020
Bosch DHZ9060
Maytag DICNF17 FREEZER- VERTICAL
Maytag DICNF17- FREEZER- VERTICAL
Maytag DICNF17C FREEZER- VERTICAL
General Electric DISR333FC2WW Gas dryer
General Electric DISR333FC3WW Gas dryer
General Electric DISR333FC4WW Gas dryer
General Electric DISR333FC5WW GAS DRYER
General Electric DISR333FC6WW GAS DRYER
General Electric DISR333FC7WW GAS DRYER
General Electric DISR333FC8WW GAS DRYER
General Electric DISR333FC9WW GAS DRYER
General Electric DISR333FCAWW GAS DRYER
General Electric DISR333FCBWW GAS DRYER
General Electric DISR333FG0WW Gas dryer
General Electric DISR333FG1WW Gas dryer
General Electric DISR333FG2WW GAS DRYER
General Electric DISR333FG3WW GAS DRYER
General Electric DISR333FG4WW GAS DRYER
General Electric DISR333FG5WW GAS DRYER
General Electric DISR333FG6WW GAS DRYER
General Electric DISR333FG7WW GAS DRYER
General Electric DISR333FG8WW GAS DRYER
General Electric DISR333FT9WW Gas dryer
General Electric DISR333FTAWW Gas dryer
General Electric DISR333FTBWW Gas dryer
General Electric DISR333KC2WW Gas dryer
General Electric DISR333KC3WW Gas dryer
General Electric DISR333KC4WW Gas dryer
General Electric DISR473CG0WW Electric dryer
General Electric DISR473CG1WW Electric dryer
General Electric DISR473CG2WW ELECTRIC DRYER
General Electric DISR473CG3WW ELECTRIC DRYER
General Electric DISR473CG4WW ELECTRIC DRYER
General Electric DISR473CG5WW ELECTRIC DRYER
General Electric DISR473CG6WW ELECTRIC DRYER
General Electric DISR473CW4WW Electric dryer
General Electric DISR473CW5WW Electric dryer
General Electric DISR473DG0WW Electric dryer
General Electric DISR473DG1WW Electric dryer
General Electric DISR473DG2WW ELECTRIC DRYER
General Electric DISR473DG3WW ELECTRIC DRYER
General Electric DISR473DG4WW ELECTRIC DRYER
General Electric DISR473DG5WW ELECTRIC DRYER
General Electric DISR473DG7WW ELECTRIC DRYER
General Electric DISR473DG8WW ELECTRIC DRYER
General Electric DISR473DG9WW ELECTRIC DRYER
General Electric DISR473DTAWW Electric dryer
General Electric DIST333JTAWW Electric dryer
General Electric DIST333JTBWW ELECTRIC DRYER
General Electric DIST333JTCWW ELECTRIC DRYER
General Electric DIST333JTDWW ELECTRIC DRYER
General Electric DIST333JTEWW ELECTRIC DRYER
General Electric DIST333JTFWW ELECTRIC DRYER
General Electric DIST333JTGWW ELECTRIC DRYER
General Electric DJSR473ET0AA Electric dryer
General Electric DJSR473ET0WW Electric dryer
General Electric DJSR473ET1WW Electric dryer
General Electric DJSR473ET2AA Electric dryer
General Electric DJSR473ET2WW Electric dryer
General Electric DJSR473ET3AA Electric dryer
General Electric DJSR473ET3WW Electric dryer
General Electric DJSR473ET5AA Electric dryer
General Electric DJSR473ET5WW Electric dryer
General Electric DJSR473ET6AA Electric dryer
General Electric DJSR473ET6WW Electric dryer
General Electric DJSR473GT0AA Gas dryer
General Electric DJSR473GT0WW Gas dryer
General Electric DJSR473GT1WW Gas dryer
General Electric DJSR473GT2AA Gas dryer
General Electric DJSR473GT2WW Gas dryer
General Electric DJSR473GT3AA Gas dryer
General Electric DJSR473GT3WW Gas dryer
General Electric DJSR473GT5AA Gas dryer
General Electric DJSR473GT5WW Gas dryer
General Electric DJSR473GT6AA Gas dryer
General Electric DJSR473GT6WW Gas dryer
General Electric DJXR433EC0CC Electric dryer
General Electric DJXR433EC0WW Electric dryer
General Electric DJXR433EC1CC Electric dryer
General Electric DJXR433EC1WW Electric dryer
General Electric DJXR433EC2CC Electric dryer
General Electric DJXR433EC2WW Electric dryer
General Electric DJXR433EC3CC Electric dryer
General Electric DJXR433EC3WW Electric dryer
General Electric DJXR433EG0CC Electric dryer
General Electric DJXR433EG0WW Electric dryer
General Electric DJXR433EG1CC ELECTRIC DRYER
General Electric DJXR433EG1WW ELECTRIC DRYER
General Electric DJXR433EG2CC ELECTRIC DRYER
General Electric DJXR433EG2WW ELECTRIC DRYER
General Electric DJXR433EG3CC ELECTRIC DRYER
General Electric DJXR433EG3WW ELECTRIC DRYER
General Electric DJXR433EG4CC ELECTRIC DRYER
General Electric DJXR433EG4WW ELECTRIC DRYER
General Electric DJXR433EG5CC ELECTRIC DRYER
General Electric DJXR433EG5WW ELECTRIC DRYER
General Electric DJXR433EG6CC ELECTRIC DRYER
General Electric DJXR433EG6WW ELECTRIC DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Coil Burnt out...replaced wont heat working4it Dryer Repair 6 12-07-2012 03:59 PM
Replaced fuse, worked than stopped KUDS01FLSS1 Dishwasher Repair 0 12-18-2011 08:34 AM
ignitor was replaced but only worked 1 day eric n Dryer Repair 0 02-16-2010 01:01 PM
Replaced Defrost Heater...worked for a while Jerry Choate Refrigerator & Freezer Repair 3 10-25-2009 12:23 PM
Replaced ignitor worked once then nothing cjkms Oven Repair (including Ranges and Cooktops) 1 08-22-2008 08:51 AM
