Register | FAQ's | New Posts | Today's Posts | Extras |
» access to heating element, thermal fuse, or thermostat heater |
![]() Model Number: LE8517W2 Brand: Amana Age: 1 - 5 years
![]() First time on a dryer w/o easy access to everything from rear panel. Some troubleshooting can be done for the no heat issue (all else works) but most requires access to the parts listed in title. How do take this thing apart properly? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Here are the parts breakdowns, should help you visualize how the unit is put together.
Parts for Amana LE8517W2 - AppliancePartsPros.com To Open It UP Front a. While supporting the lower access panel, remove two screws from bottom edge of lower front access panel b. Gently lower the access panel to disengage guide lugs from bottom edge of front panel. c. Remove two screws holding tabs on front panel to dryer side panels. Swing the bottom of front panel away from dryer far enough to disengage hold-down clips and guide lugs from cabinet top. d. Disconnect wires from door switch. Top e. Remove two cabinet top hold-down screws. f. Lift cabinet top to a vertical position by hinging it on the rear top hinges. NOTE: Cabinet top may be raised and hinged on the rear hold-down hinges or supported against wall behind dryer while servicing.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Heating element or thermal fuse? | wortonmt | Dishwasher Repair | 9 | 08-08-2014 12:10 AM |
Dryer overheat blowing thermal fuse heater box, not vent fuse | try2repairguy | Dryer Repair | 2 | 11-10-2011 08:27 AM |
dryer blowing thermal fuse on heating element | kents12 | Dryer Repair | 6 | 05-25-2011 05:25 AM |
Replace high limit thermostat a or cycling thermostat along with the thermal fuse? | BrassMonkey | Dryer Repair | 1 | 11-15-2010 06:23 PM |
Replacing heating element, thermal cutoff and high limit thermostat | courtney | Dryer Repair | 0 | 08-30-2010 11:41 AM |
