RSForcht
#1 Posted : Friday, May 24, 2013 9:30:47 AM(UTC)
RSForcht
Dryer will not heat on any setting but blower runs. I have 220V at terminal block (110 on each feed to center and 220 from outside feeds). All thermostats and thermal fuse have continuity as well as hi-limit switch. The heating element reads 11ohms.
I checked all thermostat continuity with a wire disconnected.
One of the things that I found while testing continuity, one of the leads on the push switch to start the dryer {not sure if I am saying this correctly} has continutiy to the chassis/ground.
Any hints?
Simon / APP Team
#2 Posted : Friday, May 24, 2013 11:03:57 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
OK, if you checked operating thermostat, thermal fuse, hi-limit, thermal cut off and heating element and they all good only two things left.
It's the motor contacts 1M-2M (they should be closed when motor runs) and the timer.
To check the timer set it to Timed Regular and check continuity between BK-R and TM-BY. No continuity - replace the timer
Part number: W10113761
Here are the breakdown diagrams and Washer / Dryer Control Panel parts for Whirlpool WET3300SQ1 - AppliancePartsPros.com
Post the results.
Simon.
RSForcht
#3 Posted : Friday, May 24, 2013 12:01:34 PM(UTC)
RSForcht
Thanks, Simon.
I assume that the motor contacts 1M-2M are the red wires, if I am reading the wiring diagram correctly and that the motor must be running to check for a closed circuit?
Simon / APP Team
#4 Posted : Friday, May 24, 2013 12:13:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Yes, you are correct.
Simon.
RSForcht
#5 Posted : Friday, May 24, 2013 12:29:30 PM(UTC)
RSForcht
I must be missing something. It read .02ohms. OL when not running. I first thought it was the Cycling Thermostat, so I changed it out.
RSForcht
#6 Posted : Friday, May 24, 2013 12:54:37 PM(UTC)
RSForcht
The Thermal Limiter, is it normally open or closed?
Simon / APP Team
#7 Posted : Friday, May 24, 2013 1:06:22 PM(UTC)
Simon / APP Team
Groups: APP Team
If you read .02ohms when the motor is running the switch is OK.
All the thermostats and fuses in the dryer are NC.You should read continuity.
Simon.
RSForcht
#8 Posted : Friday, May 24, 2013 1:15:45 PM(UTC)
RSForcht
Thank you very much, Simon! I thought I had checked the Thermal Limiter before, but I must have done something wrong. I jumped the connectors and she heated right up. 5:00 on a Friday is a bad time to realize such a mistake.
Thanks again!
Simon / APP Team
#9 Posted : Friday, May 24, 2013 2:20:15 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
