Discuss
Kenmore dryer not working
 in
Dryer Repair
Hi, I have a 15+ year old dryer...it started making a louder than usual humming noise in the last week
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer not working
  #1 (permalink)
Old 05-21-2013, 09:57 AM
Junior Member
JuanY is on a distinguished road
Default Kenmore dryer not working
Model Number: C110-8170091   Brand: Kenmore   Age: More than 10 years
Hi, I have a 15+ year old dryer...it started making a louder than usual humming noise in the last week and yesterday it completely stopped working. I have taken it apart and tested the different components with a multimeter and all the parts seem to show resistance...any other thoughts on trouble shooting the problem? When I press the start button, it makes a loud humming noise for a few seconds then stops. I do not know if the drum was spinning but when i try to rotate the drum manually, it does not rotate
Related Models
Hoover C1111--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1119--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1119080 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1121--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1123--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1125--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Jenn-Air C116 SURFACE UNIT- DDRAFT ELE
Jenn-Air C116-C SURFACE UNIT- DDRAFT ELE
Amana C11B FREEZER- CHEST
Amana C11B-A FREEZER- CHEST
Amana C11B-C FREEZER- CHEST
Amana C11B-G FREEZER- CHEST
Amana C11B-L FREEZER- CHEST
Amana C11F FREEZER- CHEST
Amana C11F Freezer - Chest
Amana C11F-A FREEZER- CHEST
Amana C11F-AG FREEZER- CHEST
Amana C11F-C FREEZER- CHEST
Amana C11W FREEZER- CHEST
Amana C11W-A FREEZER- CHEST
Amana C11W-AG FREEZER- CHEST
Amana C11W-C FREEZER- CHEST
Amana C122B ROOM AIR CONDITIONER
Maytag C12HE FREEZER- CHEST
Maytag C12HS FREEZER- CHEST
Maytag C12J FREEZER- CHEST
Thermador C12M 12 INCH COOKTOP MODULES
Hoover C1401--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1403--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1404--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1405--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1407--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1409910 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1411930 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1412-900
Hoover C1413930 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1414900 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1415--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1417903 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1425--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1429--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Amana C142B ROOM AIR CONDITIONER
Hoover C1431--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1433--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1439--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1498--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1498020 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1499--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1499020 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Amana C150DW FREEZER- CHEST
Amana C150FW FREEZER- CHEST
Hoover C1515--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Amana C151DW FREEZER- CHEST
Amana C151FW FREEZER- CHEST
Hoover C1525--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1527--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover C1529--- UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Maytag C15AALWH FREEZER- CHEST
Maytag C15ABLWH FREEZER- CHEST
Amana C15B FREEZER- CHEST
Amana C15B-1 FREEZER- CHEST
Amana C15B-1-A FREEZER- CHEST
Amana C15B-1-C FREEZER- CHEST
Amana C15B-1-G FREEZER- CHEST
Amana C15B-1-L FREEZER- CHEST
Amana C15B-A FREEZER- CHEST
Amana C15B-C FREEZER- CHEST
Amana C15B-G FREEZER- CHEST
Amana C15B-L FREEZER- CHEST
Amana C15B1 FREEZER- CHEST
Amana C15B1L FREEZER- CHEST
Amana C15B2L FREEZER- CHEST
  #2 (permalink)
Old 05-21-2013, 02:37 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The model number you provided is incorrect. Please check and re post.
Try to turn the motor both directions. Is it jammed?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-21-2013, 10:16 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
hi simon, the model # is C110_8170091...reading it directly off the stamped plate by the door...is the C a designation for Sears Canada (I do live in Canada)? Other information serial#9GK3891, Type DR-6, 120/240 Volts, 24 Amps, 60HZ
I can turn the motor shaft in both directions however when the dryer was still assembled, I could not seem to rotate the drum
  #4 (permalink)
Old 05-22-2013, 10:13 AM
Expert
Default
Hi.
Yes, you are right. It's a Canadien model number, I can't look it up.
Try to do this - tape the door switch in, push the start button and turn the drum.
If the dryer starts, then the motor is bad.
Sorry, can't be more specific.
Simon.
__________________
  #5 (permalink)
Old 05-24-2013, 11:40 AM
Junior Member
Default
hi Simon, I reassembled the dryer and pressed start and it seems to be working again????
I ran it a few minutes empty and it sounded ok. I tried a full load and noticed the dryer sounds being louder. after the dryer stopped, it restarted (as per normal) and it sounded like a loud screech at first and then back to normal. IS this an indicator the drum belt needs to be replaced? That the belt is becoming worn and not gripping the drum as snugly as before?
  #6 (permalink)
Old 05-24-2013, 01:54 PM
Expert
Default
It's not the belt. Check if the drum is rotating freely. Also it may be the motor.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Dryer Not Working silverevo05 Dryer Repair 2 02-14-2012 05:44 PM
Kenmore Washer+Dryer, Dryer not working Sgat8516 Dryer Repair 11 03-29-2011 03:10 PM
kenmore dryer not working nfg kenmore Dryer Repair 1 12-10-2010 02:02 AM
kenmore dryer not working alfee Dryer Repair 2 02-09-2009 04:47 AM
Kenmore dryer stopped working dcn0021 Dryer Repair 0 01-25-2008 01:55 PM
