Discuss
Intermittent Heat
 in
Dryer Repair
The dryer heats for a while, and then the heat shuts off. It still tumbles. After a few moments, by
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Intermittent Heat
  #1 (permalink)
Old 05-19-2013, 04:38 PM
Junior Member
gvel is on a distinguished road
Default Intermittent Heat
Model Number: LGR8648   Brand: Whirlpool   Age: 5 - 10 years
The dryer heats for a while, and then the heat shuts off. It still tumbles. After a few moments, by shutting the dryer down, it will heat again.
Of course, the thermal fuse is ok, since the burner kicks in sometimes. It shows good continuity too.
Thanks, in advance, for your help.
Related Models
Whirlpool LGR8648LG1 29"GAS DRYER
Whirlpool LGR8648LQ0 RESIDENTIAL DRYER
Whirlpool LGR8648LW0 RESIDENTIAL DRYER
Whirlpool LGR8648LW1 29"GAS DRYER
Whirlpool LGR8648PG0 29"GAS DRYER
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" GAS DRYER
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"GAS DRYER
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0 GAS DRYER
Whirlpool LGR8857EQ1 DRYERS
Whirlpool LGR8857EQ2 GAS DRYER
Whirlpool LGR8857EQ3 GAS DRYER
Whirlpool LGR8857EZ0 GAS DRYER
Whirlpool LGR8857EZ1 DRYERS
Whirlpool LGR8857EZ2 GAS DRYER
Whirlpool LGR8857EZ3 GAS DRYER
Whirlpool LGR8858DQ0 GAS DRYER
Whirlpool LGR8858DQ1 GAS DRYER
Whirlpool LGR8858DZ0 GAS DRYER
Whirlpool LGR8858DZ1 GAS DRYER
Whirlpool LGR8858EQ0 GAS DRYER
Whirlpool LGR8858EQ1 DRYERS
Whirlpool LGR8858EQ2 GAS DRYER
Whirlpool LGR8858EQ3 GAS DRYER
Whirlpool LGR8858EZ0 GAS DRYER
Whirlpool LGR8858EZ1 DRYERS
Whirlpool LGR8858EZ2 GAS DRYER
Whirlpool LGR8858EZ3 GAS DRYER
Amana LGS10AW WASHER-TOP LOADING
Amana LGS19AW DRYER- GAS
Amana LGS33AW DRYER- GAS
Amana LGS34AW WASHER-TOP LOADING
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AQ0 Residential Dryer
Whirlpool LGT5434AW0 Residential Dryer
Whirlpool LGT5436AW0 Residential Dryer
Whirlpool LGT5624BN0 GAS DRYER
Whirlpool LGT5624BN1 GAS DRYER
Whirlpool LGT5624BN2 GAS DRYER
Whirlpool LGT5624BQ0 GAS DRYER
Whirlpool LGT5624BQ1 GAS DRYER
Whirlpool LGT5624BQ2 GAS DRYER
Whirlpool LGT5624BW0 GAS DRYER
Whirlpool LGT5624BW1 GAS DRYER
Whirlpool LGT5624BW2 GAS DRYER
Whirlpool LGT5624DQ0 GAS DRYER
Whirlpool LGT5624DQ1 GAS DRYER
Whirlpool LGT6634AN1 DRYER
Whirlpool LGT6634AN2 GAS DRYER
Whirlpool LGT6634AQ0 GAS DRYER
Whirlpool LGT6634AQ1 GAS DRYER
Whirlpool LGT6634AQ2 GAS DRYER
Whirlpool LGT6634AW0 Residential Dryer
Whirlpool LGT6634AW1 DRYER
Whirlpool LGT6634AW2 GAS DRYER
Whirlpool LGT6634DQ0 GAS DRYER
Whirlpool LGT6634DQ1 GAS DRYER
Whirlpool LGT6634DZ0 GAS DRYER
Whirlpool LGT6634DZ1 GAS DRYER
Whirlpool LGT6638AN1 GAS DRYER
Whirlpool LGT6638AN2 GAS DRYER
Whirlpool LGT6638AQ2 GAS DRYER
Whirlpool LGT6638AW0 Residential Dryer
Whirlpool LGT6638AW1 GAS DRYER
Whirlpool LGT6638AW2 GAS DRYER
Whirlpool LGT6638DQ0 GAS DRYER
Whirlpool LGT6638DQ1 GAS DRYER
Whirlpool LGT6638DZ0 GAS DRYER
Whirlpool LGT6638DZ1 GAS DRYER
Whirlpool LGT7646AQ0 Residential Dryer
Whirlpool LGT7646AQ2 GAS DRYER
Whirlpool LGT7646AW0 Residential Dryer
Whirlpool LGT7646AZ2 GAS DRYER
Whirlpool LGT7646DQ0 GAS DRYER
Whirlpool LGT7646DQ1 GAS DRYER
Whirlpool LGT7646DZ0 GAS DRYER
Whirlpool LGT7646DZ1 GAS DRYER
Whirlpool LGT7646EQ0 GAS DRYER
Whirlpool LGT7646EQ1 DRYERS
Whirlpool LGT7646EQ2 GAS DRYER
Whirlpool LGT7646EQ3 GAS DRYER
Whirlpool LGT7646EZ0 GAS DRYER
Whirlpool LGT7646EZ1 DRYERS
Whirlpool LGT7646EZ2 GAS DRYER
Whirlpool LGT7646EZ3 GAS DRYER
Whirlpool LGT7848AQ0 Residential Dryer
Whirlpool LGT7848AQ1 GAS DRYER
Whirlpool LGT7848AQ2 GAS DRYER
Whirlpool LGT7848AW0 Residential Dryer
Whirlpool LGT7848AZ1 GAS DRYER
Whirlpool LGT7848AZ2 GAS DRYER
Whirlpool LGT7848DQ0 GAS DRYER
Whirlpool LGT7848DQ1 GAS DRYER
Whirlpool LGT7848DZ0 GAS DRYER
Whirlpool LGT7848DZ1 GAS DRYER
Whirlpool LGT8858AN1 GAS DRYER
Whirlpool LGT8858AN2 GAS DRYER
Whirlpool LGT8858AQ0 GAS DRYER
Whirlpool LGT8858AQ1 GAS DRYER
Whirlpool LGT8858AQ2 GAS DRYER
Whirlpool LGT8858AW0 Residential Dryer
Whirlpool LGT8858AW1 GAS DRYER
Whirlpool LGT8858AW2 GAS DRYER
Whirlpool LGT8858AZ0 GAS DRYER
Whirlpool LGT8858AZ1 GAS DRYER
Whirlpool LGT8858AZ2 GAS DRYER
Whirlpool LGT8858DQ0 GAS DRYER
Whirlpool LGT8858DQ1 GAS DRYER
Whirlpool LGT8858DZ0 GAS DRYER
Whirlpool LGT8858DZ1 GAS DRYER
Frigidaire LGUB2642LE3 REFRIGERATOR
Frigidaire LGUB2642LE4 REFRIGERATOR
Frigidaire LGUB2642LF0 REFRIGERATOR
Frigidaire LGUB2642LF1 REFRIGERATOR
Frigidaire LGUB2642LF2 REFRIGERATOR
Frigidaire LGUB2642LF3 REFRIGERATOR
Frigidaire LGUB2642LF4 REFRIGERATOR
Frigidaire LGUB2642LP3 FRIGIDAIRE/REFRIGERATOR
  #2 (permalink)
Old 05-20-2013, 03:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Most likely the problem is a bad gas valve coils.
- The gas valve coil kit Part number: 279834
Part number: 279834
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Intermittent Heat rcady52 Dryer Repair 5 11-01-2012 02:10 PM
Intermittent Problem w/ Heat rjl41 Dryer Repair 0 12-09-2009 04:48 PM
Intermittent Heat docsaintly Dryer Repair 1 07-31-2009 09:49 AM
Intermittent heat fxn001 Dryer Repair 1 07-13-2009 01:18 PM
Intermittent Heat ASinSeattle Dryer Repair 0 12-22-2008 08:20 PM
