Discuss
NO run but heat is on
 in
Dryer Repair
This dryer will not run (drum does not turn) but the heater is on. In diagnostic mode I get error
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » NO run but heat is on
  #1 (permalink)
Old 05-18-2013, 08:08 PM
Junior Member
gdurante is on a distinguished road
Unhappy NO run but heat is on
Model Number: WED6200SW1   Brand: Whirlpool   Age: 1 - 5 years
In diagnostic mode I get error code F31.This error code I cannot find it anywhere. I already replaced thermal fuse ounce. Based on the wiring diagram the heater should not be on if the drive motor is not turning. I suspect a bad centrifugal motor switch. My question is: if its the centrifugal switch do I need to replace the motor or can I just replace the centri switch?
Related Models
Whirlpool WED6200SW1 29"ELECTRIC DRYER
Whirlpool WED6400SB0 29"ELECTRIC DRYER
Whirlpool WED6400SB1 29" ELECTRIC DRYER
Whirlpool WED6400SG0 29"ELECTRIC DRYER
Whirlpool WED6400SG1 29" ELECTRIC DRYER
Whirlpool WED6400SW0 29"ELECTRIC DRYER
Whirlpool WED6400SW1 29" ELECTRIC DRYER
Whirlpool WED6600VU0 29" ELECTRIC DRYER
Whirlpool WED6600VW0 29" ELECTRIC DRYER
Whirlpool WED6600WL0 29"ELECTRIC DRYER
Whirlpool WED7300XW0 27" ELECTRIC DRYER
Whirlpool WED7400XW0 27"ELECTRIC DRYER
Whirlpool WED7500VW0 COMPACT ELECTRIC DRYER
Whirlpool WED7600XW0 27" ELECTRIC DRYER
Whirlpool WED7800XB0 27" ELECTRIC DRYER
Whirlpool WED7800XL0 27" ELECTRIC DRYER
Whirlpool WED7800XW0 27" ELECTRIC DRYER
Whirlpool WED7990XG0 29" ELECTRIC DRYER
Whirlpool WED8200YW0 27" ELECTRIC DRYER
Whirlpool WED8300SB0 27" Electric Dryer
Whirlpool WED8300SB1 27" Electric Dryer
Whirlpool WED8300SB2 27" Electric Dryer
Whirlpool WED8300SE2 27" ELECTRIC DRYER
Whirlpool WED8300SW0 27" Electric Dryer
Whirlpool WED8300SW1 27" Electric Dryer
Whirlpool WED8300SW2 27" Electric Dryer
Whirlpool WED8410SW0 27"Electric Dryer
Whirlpool WED8410SW1 27" Electric Dryer
Whirlpool WED8410SW2 27" ELECTRIC DRYER
Whirlpool WED8500SR0 27"Electric Dryer
Whirlpool WED8600YW0 27" ELECTRIC DRYER
Whirlpool WED8800YC0 27" ELECTRIC DRYER
Whirlpool WED8800YW0 27" ELECTRIC DRYER
Whirlpool WED9050XW0 27" ELECTRIC DRYER
Whirlpool WED9050XW1 27" ELECTRIC DRYER
Whirlpool WED9150WW0 27" ELECTRIC DRYER
Whirlpool WED9150WW1 27" ELECTRIC DRYER
Whirlpool WED9151YW0 27" ELECTRIC DRYER
Whirlpool WED9200SQ0 ELECTRIC DRYER
Whirlpool WED9200SQ1 ELECTRIC DRYER
Whirlpool WED9200SQ2 ELECTRIC DRYER
Whirlpool WED9250WL0 27" ELECTRIC DRYER
Whirlpool WED9250WL1 27" ELECTRIC DRYER
Whirlpool WED9250WR0 27" ELECTRIC DRYER
Whirlpool WED9250WR1 27" ELECTRIC DRYER
Whirlpool WED9250WW0 27" ELECTRIC DRYER
Whirlpool WED9250WW1 27" ELECTRIC DRYER
Whirlpool WED9270XL0 27" ELECTRIC DRYER
Whirlpool WED9270XL1 27" ELECTRIC DRYER
Whirlpool WED9270XL2 27" ELECTRIC DRYER
Whirlpool WED9270XR0 27" ELECTRIC DRYER
Whirlpool WED9270XR1 27" ELECTRIC DRYER
Whirlpool WED9270XR2 27" ELECTRIC DRYER
Whirlpool WED9270XW0 27" ELECTRIC DRYER
Whirlpool WED9270XW1 27" ELECTRIC DRYER
Whirlpool WED9270XW2 27" ELECTRIC DRYER
Whirlpool WED9300VU0 ELECTRIC DRYER
Whirlpool WED9300VU1 ELECTRIC DRYER
Whirlpool WED9371YL0 27" ELECTRIC DRYER
Whirlpool WED9371YW0 27" ELECTRIC DRYER
Whirlpool WED9400SB0 ELECTRIC DRYER
Whirlpool WED9400SB1 ELECTRIC DRYER
Whirlpool WED9400ST0 ELECTRIC DRYER
Whirlpool WED9400ST1 ELECTRIC DRYER
Whirlpool WED9400SU0 ELECTRIC DRYER
Whirlpool WED9400SU1 ELECTRIC DRYER
Whirlpool WED9400SU2 ELECTRIC DRYER
Whirlpool WED9400SW0 ELECTRIC DRYER
Whirlpool WED9400SW1 ELECTRIC DRYER
Whirlpool WED9400SW2 ELECTRIC DRYER
Whirlpool WED9400SZ0 ELECTRIC DRYER
Whirlpool WED9400SZ1 ELECTRIC DRYER
Whirlpool WED9400SZ2 ELECTRIC DRYER
Whirlpool WED9400VE0 ELECTRIC DRYER
Whirlpool WED9400VE1 ELECTRIC DRYER
Whirlpool WED9450WL0 ELECTRIC DRYER
Whirlpool WED9450WL1 ELECTRIC DRYER
Whirlpool WED9450WR0 ELECTRIC DRYER
Whirlpool WED9450WR1 ELECTRIC DRYER
Whirlpool WED9450WW0 ELECTRIC DRYER
Whirlpool WED9450WW1 ELECTRIC DRYER
Whirlpool WED9470WL1 ELECTRIC DRYER
Whirlpool WED9470WR1 ELECTRIC DRYER
Whirlpool WED9470WW1 ELECTRIC DRYER
Whirlpool WED94HEXL0 DRYER
Whirlpool WED94HEXL1 27" ELECTRIC DRYER
Whirlpool WED94HEXR0 DRYER
Whirlpool WED94HEXR1 27" ELECTRIC DRYER
Whirlpool WED94HEXW0 DRYER
Whirlpool WED94HEXW1 27" ELECTRIC DRYER
Whirlpool WED9500TC0 ELECTRIC DRYER
Whirlpool WED9500TC1 ELECTRIC DRYER
Whirlpool WED9500TC2 ELECTRIC DRYER
Whirlpool WED9500TU0 ELECTRIC DRYER
Whirlpool WED9500TU1 ELECTRIC DRYER
Whirlpool WED9500TW0 ELECTRIC DRYER
Whirlpool WED9500TW1 ELECTRIC DRYER
Whirlpool WED9500TW2 ELECTRIC DRYER
Whirlpool WED9500TW3 ELECTRIC DRYER
Whirlpool WED9550WL0 ELECTRIC DRYER
Whirlpool WED9550WL1 ELECTRIC DRYER
Whirlpool WED9550WR0 ELECTRIC DRYER
Whirlpool WED9550WR1 ELECTRIC DRYER
Whirlpool WED9550WW0 ELECTRIC DRYER
Whirlpool WED9550WW1 ELECTRIC DRYER
Whirlpool WED95HEXL0 DRYER
Whirlpool WED95HEXL1 27" ELECTRIC DRYER
Whirlpool WED95HEXR0 DRYER
Whirlpool WED95HEXR1 27" ELECTRIC DRYER
Whirlpool WED95HEXW0 DRYER
Whirlpool WED95HEXW1 27" ELECTRIC DRYER
Whirlpool WED9600SU0 ELECTRIC DRYER
Whirlpool WED9600TA0 27" ELECTRIC DRYER
Whirlpool WED9600TA1 27" ELECTRIC DRYER
Whirlpool WED9600TA2 27" ELECTRIC DRYER
Whirlpool WED9600TB0 27" ELECTRIC DRYER
Whirlpool WED9600TB1 27" ELECTRIC DRYER
Whirlpool WED9600TU0 27" ELECTRIC DRYER
Whirlpool WED9600TU1 27" ELECTRIC DRYER
Whirlpool WED9600TW0 27" ELECTRIC DRYER
  #2 (permalink)
Old 05-22-2013, 01:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Whirlpool WED6200SW1 Dryer - AppliancePartsPros.com
You have to replace the motor (item 47 in the Cabinet Parts section).
Before ordering anything I would open the unit up and check the motor.
It could be that the motor is clogged solid with lint and the centrifugal mechanism in the motor is jammed in the activated position.
Also remove the blower wheel (reverse thread) from the motor shaft.
Often these are seized to the shaft and have to be destroyed, so you may also need a new blower.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 11:23 AM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
