Discuss
Dryer help????
 in
Dryer Repair
I have a Kenmore Elite Smartheat Quitepak9 gas dryer. It will only work if I keep switching from pushing the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer help????
  #1 (permalink)
Old 05-16-2013, 05:34 PM
Junior Member
Chrisbot is on a distinguished road
Angry Dryer help????
Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore Elite Smartheat Quitepak9 gas dryer. It will only work if I keep switching from pushing the start button to pause button and so on. Eventually it will start but only runs for a bit then I have to repeat the whole process. I order a thermal fuse but did not work. PLEASE HELP
  #2 (permalink)
Old 05-16-2013, 08:37 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hello.
Please, provide the complete model number of the dryer.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-17-2013, 05:29 PM
Junior Member
Default
The Model number is 110.95862401
The Serial number is MS2201031
  #4 (permalink)
Old 05-18-2013, 03:22 PM
Junior Member
Default
ran diagnostics no errors. Ran test for moisture sensor and it failed. Took apart the sensors and cleaned them up and now it passes. Any other ideas anybody. Thermistor test passed as well.
  #5 (permalink)
Old 05-20-2013, 10:35 AM
Expert
Default
Hello.
Most likely the problem is with main control board
Part number: 8546219
Remove it and check the solderind at the back. Possibly one of the relay's contacts needs a drop of solder.
If not then try to replace the control board.
Post ther results.
Simon.
P.S. You can return the part if it's not going to fix the problem.
__________________
  #6 (permalink)
Old 05-21-2013, 04:41 PM
Junior Member
Default
Ok I will take a look at the board thank you for the advice.
  #7 (permalink)
Old 05-21-2013, 05:12 PM
Expert
Default
You are welcome.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
