Maytag Centennial not drying
Dryer Repair
My gas centennial has stopped drying things? It seems to not be getting hot. I had it on Automatic dry
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Centennial not drying
  #1 (permalink)
Old 05-15-2013, 11:36 AM
Junior Member
brmartin is on a distinguished road
Default Maytag Centennial not drying
Model Number: mgdc400vwd   Brand: Maytag   Age: 1 - 5 years
My gas centennial has stopped drying things? It seems to not be getting hot. I had it on Automatic dry (high heat) under energy preferred setting, came to switch about 2 hours later and was still on same setting and clothes were cold and damp?
Related Models
Maytag MGDC500VW0 29" GAS DRYER
Maytag MGDC500VW1 29" GAS DRYER
Maytag MGDC700VJ0 27" GAS DRYER
Maytag MGDC700VJ1 27" GAS DRYER
Maytag MGDC700VW0 27" GAS DRYER
Maytag MGDC700VW1 27" GAS DRYER
Maytag MGDE200XW0 27" GAS DRYER
Maytag MGDE300VF0 29" GAS DRYER
Maytag MGDE300VF1 29" GAS DRYER
Maytag MGDE300VF2 29" GAS DRYER
Maytag MGDE300VF3 29" GAS DRYER
Maytag MGDE300VW0 29" GAS DRYER
Maytag MGDE300VW1 29" GAS DRYER
Maytag MGDE300VW3 29" GAS DRYER
Maytag MGDE400XR0 29" GAS DRYER
Maytag MGDE400XW0 29" GAS DRYER
Maytag MGDE500VF0 29" GAS DRYER
Maytag MGDE500VF1 29" GAS DRYER
Maytag MGDE500VP0 29" GAS DRYER
Maytag MGDE500VP1 29" GAS DRYER
Maytag MGDE500VW0 29" GAS DRYER
Maytag MGDE500VW1 29" GAS DRYER
Maytag MGDE500VW2 29" GAS DRYER
Maytag MGDE500WJ0 29" GAS DRYER
Maytag MGDE500WJ1 29" GAS DRYER
Maytag MGDE500WR0 29" GAS DRYER
Maytag MGDE500WR1 29" GAS DRYER
Maytag MGDE900VJ0 29" GAS DRYER
Maytag MGDE900VJ1 29" GAS DRYER
Maytag MGDE900VJ2 29" GAS DRYER
Maytag MGDE900VW0 29" GAS DRYER
Maytag MGDE900VW1 29" GAS DRYER
Maytag MGDE900VW2 29" GAS DRYER
Maytag MGDX500XL0 27" GAS DRYER
Maytag MGDX500XW0 27" GAS DRYER
Maytag MGDX550XW0 27" GAS DRYER
Maytag MGDX600XW0 27" GAS DRYER
Maytag MGDZ400TQ1 27" GAS DRYER
Maytag MGDZ400TQ2 27" GAS DRYER
Maytag MGDZ600TB1 27" GAS DRYER
Maytag MGDZ600TB2 27" GAS DRYER
Maytag MGDZ600TE2 27" GAS DRYER
Maytag MGDZ600TK1 27" GAS DRYER
Maytag MGDZ600TK2 27" GAS DRYER
Maytag MGDZ600TW1 27" GAS DRYER
Maytag MGDZ600TW2 27" GAS DRYER
Maytag MGDZ600WR0 27" GAS DRYER
Frigidaire MGF200PBDA Frg(v2) / Gas Range
Frigidaire MGF200PBDB Frg(v1) / Gas Range
Frigidaire MGF200PBWA Frg(v1) / Gas Range
Frigidaire MGF200PBWB Frg(v2) / Gas Range
Frigidaire MGF240GSA GAS RANGE
Frigidaire MGF300PBDA Frg(v1) / Gas Range
Frigidaire MGF300PBDB Wwh(v17) / Gas Range
Frigidaire MGF300PBDC Kel(v1) / Gas Range
Frigidaire MGF300PBDD Frg(v1) / Gas Range
Frigidaire MGF300PBDE Frg(v1) / Gas Range
Frigidaire MGF300PBDF Frg(v1) / Gas Range
Frigidaire MGF300PBDG Frg(v2) / Gas Range
Frigidaire MGF300PBDH
Frigidaire MGF300PBWA Frg(v2) / Gas Range
Frigidaire MGF300PBWB Wwh(v18) / Gas Range
Frigidaire MGF300PBWC Kel(v2) / Gas Range
Frigidaire MGF300PBWD Frg(v2) / Gas Range
Frigidaire MGF300PBWE Frg(v2) / Gas Range
Frigidaire MGF300PBWF Frg(v3) / Gas Range
Frigidaire MGF300PBWG Frg(v4) / Gas Range
Frigidaire MGF300PBWH
Frigidaire MGF301SBDA Frg(v1) / Gas Range
Frigidaire MGF301SBWA Frg(v2) / Gas Range
Frigidaire MGF303PGDA Frg(v1) / Gas Range
Frigidaire MGF303PGDC Frg(v1) / Gas Range
Frigidaire MGF303PGDD Frg(v2) / Gas Range
Frigidaire MGF303PGDE Frg(v3) / Gas Range
Frigidaire MGF303PGDG Universal/gas Range
Frigidaire MGF303PGDH Universal/gas Range
Frigidaire MGF303PGDJ Universal/gas Range
Frigidaire MGF303PGDK Universal/gas Range
Frigidaire MGF303PGDL Universal/gas Range
Frigidaire MGF303PGWA Frg(v2) / Gas Range
Frigidaire MGF303PGWC Frg(v4) / Gas Range
Frigidaire MGF303PGWD Frg(v5) / Gas Range
Frigidaire MGF303PGWE Frg(v6) / Gas Range
Frigidaire MGF303PGWG Universal/gas Range
Frigidaire MGF303PGWH Universal/gas Range
Frigidaire MGF303PGWJ Universal/gas Range
Frigidaire MGF303PGWK Universal/gas Range
Frigidaire MGF303PGWL Universal/gas Range
Frigidaire MGF311SBDA Frg(v3) / Gas Range
Frigidaire MGF311SBDB Wwh(v19) / Gas Range
Frigidaire MGF311SBDC Frg(v1) / Gas Range
Frigidaire MGF311SBDD Frg(v1) / Gas Range
Frigidaire MGF311SBDE Frg(v1) / Gas Range
Frigidaire MGF311SBDF Frg(v1) / Gas Range
Frigidaire MGF311SBWA Frg(v4) / Gas Range
Frigidaire MGF311SBWB Wwh(v20) / Gas Range
Frigidaire MGF311SBWC Frg(v2) / Gas Range
Frigidaire MGF311SBWD Frg(v2) / Gas Range
Frigidaire MGF311SBWE Frg(v2) / Gas Range
Frigidaire MGF311SBWF Frg(v2) / Gas Range
Frigidaire MGF312SBDA Frg(v1) / Gas Range
Frigidaire MGF312SBDC Frg(v1) / Gas Range
Frigidaire MGF312SBWA Frg(v2) / Gas Range
Frigidaire MGF312SBWB
Frigidaire MGF312SBWC Frg(v2) / Gas Range
Frigidaire MGF313SCDB Frg(v1) / Gas Range
Frigidaire MGF313SCDC Frg(v1) / Gas Range
Frigidaire MGF313SCWB Frg(v2) / Gas Range
Frigidaire MGF313SCWC Frg(v2) / Gas Range
Frigidaire MGF316WFSA Frg(v0) / Gas Range
Frigidaire MGF316WFSB Frg(v0) / Gas Range
Frigidaire MGF316WFSC Frg(v1) / Gas Range
Frigidaire MGF316WFTC Frg(v2) / Gas Range
Frigidaire MGF316WGSA Frg(v0) / Gas Range
Frigidaire MGF316WGSC Frg(v1) / Gas Range
Frigidaire MGF316WGSD Frg(v1) / Gas Range
Frigidaire MGF316WGSE Frg(v2) / Gas Range
Frigidaire MGF316WGSF Frg(v3) / Gas Range
Frigidaire MGF316WGSG Universal/gas Range
Frigidaire MGF316WGSH Universal/gas Range
  #2 (permalink)
Old 05-15-2013, 06:01 PM
Simon / APP Team's Avatar
Simon / APP Team will become famous soon enough
You would need a multimeter to run the tests. if you have one - buckle up!
Remove the rear cover from the dryer and locate thermal fuse
Part number: 3392519
Pull one wire off and check continuity. If it's open (no continuity) - replace the fuse and make sure that entire exhaust system is clean.
Next check the thermal cut-off and limit thermostat
Part number: W10480709
Replace if open.
Here are the breakdown diagrams and 03-Bulkhead Parts parts for Maytag MGDC400VW0 - AppliancePartsPros.com
Please let us know the results of the tests.
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Centennial Won't Fill dahornor Washer Repair 3 05-29-2013 06:34 AM
Maytag Centennial washer Ila Ross Washer Repair 1 07-09-2012 05:27 PM
Maytag Centennial Dryer mcurt1 Dryer Repair 2 03-20-2012 05:40 AM
Maytag Centennial Dryer New candleice Dryer Repair 1 03-19-2012 04:34 AM
