Discuss
Coversion from LP to NatGas
 in
Dryer Repair
During conversion from LP back to Nat Gas items 16 & 17 & 18 (see attachment) were accidentally removed then
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Coversion from LP to NatGas
  #1 (permalink)
Old 05-13-2013, 11:23 AM
Junior Member
carons1 is on a distinguished road
Default Coversion from LP to NatGas
Model Number: RGX4625EW1   Brand: Roper   Age: More than 10 years
During conversion from LP back to Nat Gas items 16 & 17 & 18 (see attachment) were accidentally removed then reinstalled. The items are called:
16 - Limiter
17 - Regulator
18 - Spring
Is it possible that item 17, if not screwed in to the correct depth could affect gas flow to the burner? Either too low or (worse) too high flame?
In my case, it is taking too long for the clothes to dry. The tub never really gets very warm.
I have not yet had a chance to observe if the valve is short-cycling or staying on but just very low flame.
Related Models
Roper RGX4625EW1 DRYERS
Roper RGX4625EW2 GAS DRYER
Roper RGX4625EW3 GAS DRYER
Roper RGX4634JQ0 DRYER
Roper RGX4634KQ1 DRYER
Roper RGX4634KQ2 DRYER
Roper RGX4634KQ3 29" GAS DRYER
Roper RGX4635EN0 GAS DRYER
Roper RGX4635EN1 DRYERS
Roper RGX4635EN2 GAS DRYER
Roper RGX4635EN3 GAS DRYER
Roper RGX4635EQ0 GAS DRYER
Roper RGX4635EQ1 DRYERS
Roper RGX4635EQ2 GAS DRYER
Roper RGX4635EQ3 GAS DRYER
Roper RGX4635EW0 GAS DRYER
Roper RGX4635EW1 DRYERS
Roper RGX4635EW2 GAS DRYER
Roper RGX4635EW3 GAS DRYER
Roper RGX5634JQ0 DRYER
Roper RGX5634JQ1 DRYER
Roper RGX5634KQ1 DRYER
Roper RGX5634KQ2 DRYER
Roper RGX5634KQ3 29" GAS DRYER
Roper RGX5634PQ0 29" GAS DRYER
Roper RGX5635EN0 GAS DRYER
Roper RGX5635EN1 DRYERS
Roper RGX5635EN2 GAS DRYER
Roper RGX5635EN3 GAS DRYER
Roper RGX5635EQ0 GAS DRYER
Roper RGX5635EQ1 DRYERS
Roper RGX5635EQ2 GAS DRYER
Roper RGX5635EQ3 GAS DRYER
Roper RGX5635EW0 GAS DRYER
Roper RGX5635EW1 DRYERS
Roper RGX5635EW2 GAS DRYER
Roper RGX5635EW3 GAS DRYER
Roper RGX5636AL1 GAS DRYER
Roper RGX5636AL2 GAS DRYER
Roper RGX5636AW0 Residential Dryer
Roper RGX5636AW1 GAS DRYER
Roper RGX5636AW2 GAS DRYER
Roper RGX6634PQ0 29" GAS DRYER
Roper RGX6634RQ0 29" GAS DRYER
Roper RGX6634RQ1 29" GAS DRYER
Roper RGX6646AL1 GAS DRYER
Roper RGX6646AL2 GAS DRYER
Roper RGX6646AL3 GAS DRYER
Roper RGX6646AQ2 GAS DRYER
Roper RGX6646AQ3 GAS DRYER
Roper RGX6646AW0 Residential Dryer
Roper RGX6646AW1 GAS DRYER
Roper RGX6646AW2 GAS DRYER
Roper RGX6646AW3 GAS DRYER
Roper RH0500RAW00 CHEST FREEZER
Roper RH0500RDW00 CHEST FREEZER
Roper RH0500REW00 CHEST FREEZER
Roper RH0500REW01 CHEST FREEZER
Roper RH0500REW02 CHEST FREEZER
Roper RH0500RWW00 Freezers*
Roper RH0588RBW00 CHEST FREEZER
Roper RH0588REW00 CHEST FREEZER
Roper RH0588REW01 CHEST FREEZER
Roper RH0588REW02 CHEST FREEZER
Roper RH0599RBW00 CHEST FREEZER
Roper RH0599REW00 CHEST FREEZER
Roper RH0599REW01 CHEST FREEZER
Roper RH0599REW02 CHEST FREEZER
Roper RH0799RBW00 CHEST FREEZER
Roper RH0799REW00 CHEST FREEZER
Roper RH0799REW01 CHEST FREEZER
Roper RH0799REW06 FREEZERS
Jenn-Air RH100 HOOD
Roper RH1000RAW00 Freezers*
Roper RH1000RDW00 CHEST FREEZER
Roper RH1000REW00 CHEST FREEZER
Roper RH1000REW01 CHEST FREEZER
Roper RH1000REW05 CHEST FREEZER
Roper RH1000REW06 FREEZERS
Roper RH1000RYW00 Freezers*
Jenn-Air RH101 HOOD
Roper RH1099RBW00 CHEST FREEZER
Roper RH1099REW00 CHEST FREEZER
Roper RH1099REW06 FREEZERS
Roper RH1200RWW00 Freezers*
Roper RH1200RXW00 Freezers*
Whirlpool RH123 Air-conditioner/heat pump
Whirlpool RH123A1 AIR CONDITIONER
Whirlpool RH123A2 AIR CONDITIONERS
Jenn-Air RH130 HOOD
Roper RH1500RAW00 CHEST FREEZER
Roper RH1500RDW00 CHEST FREEZER
Roper RH1500REW00 CHEST FREEZER
Roper RH1500REW01 FREEZERS
Roper RH1500REW02 CHEST FREEZER
Roper RH1500REW03 FREEZERS
Roper RH1500REW04 FREEZER
Roper RH1500REW05 CHEST FREEZER
Roper RH1500REW06 FREEZERS
Roper RH1500RWW00 Freezers*
Roper RH1500RXW00 Freezers*
Roper RH1599RBW00 CHEST FREEZER
Roper RH1599REW00 CHEST FREEZER
Roper RH1599REW03 FREEZERS
Roper RH1599REW04 FREEZERS
Roper RH1599REW06 FREEZERS
Jenn-Air RH170 HOOD
Jenn-Air RH180B HOOD
Jenn-Air RH180W HOOD
Whirlpool RH183 Air-conditioner/heat pump
Jenn-Air RH186B HOOD
Jenn-Air RH186W HOOD
Jenn-Air RH200 HOOD
Whirlpool RH2024XLW0 Range Hood
Whirlpool RH2024XLW1 Range Hood
Whirlpool RH2030WXW0 Range Hood
Whirlpool RH2030XDB0 30" RANGE HOOD
Whirlpool RH2030XDB1 RANGE HOOD
Whirlpool RH2030XDQ0 30" RANGE HOOD
Whirlpool RH2030XDQ1 RANGE HOOD
  #2 (permalink)
Old 05-13-2013, 11:25 AM
Junior Member
Default
Quote:
Originally Posted by carons1 View Post
During conversion from LP back to Nat Gas items 16 & 17 (see attachment) were accidentally removed then reinstalled. The items are called:
15 - Limiter
16 - Regulator
17 - Spring
Is it possible that item 16, if not screwed in to the correct depth could affect gas flow to the burner? Either too low or (worse) too high flame?
Attachment 6094
NOTE CORRECTION TO #'S
  #3 (permalink)
Old 05-13-2013, 06:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
How did you do that conversion? Which parts did you replace?
Here are the breakdown diagrams and Parts for Roper RGX4625EW1 Dryer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Coversion to LP gas manual kopinion Oven Repair (including Ranges and Cooktops) 0 08-05-2010 05:27 PM
Help with coversion from LPG to NG Mark440 Dryer Repair 3 05-27-2009 10:21 AM
