block
#1 Posted : Tuesday, October 6, 2009 6:46:32 AM(UTC)
block
when you turn the dryer off the sensor will come on in a few seconds also if you are drying a load it will not cut off after it is dry. I removed the sensor and cleaned it but didn,t correct the problem.
SublimeMasterJW
#2 Posted : Tuesday, October 6, 2009 8:31:31 AM(UTC)
SublimeMasterJW
You either have a bad control or bad connection between the sensors and the control,or a bad wire.
