The Dryer would not dry clothes. evrything worked except for the heat. I have taken the unit apart and cleaned all the lint out. I check to make sure the ignitor lit and the burner came on. everything looked fine. I put it together and the burner would light then go out after a few seconds and not come back on. Everytime I turn it off it does the same thing the ignitor lights, the burner comes on then goes off after a few seconds. I can hear a switch trip when the burner goes out. Any idea what it could be?
