Discuss
Replacing Drum Roller wheel(s)
 in
Dryer Repair
This is the first time I've had to replace a squeeky wheel on this unit, but I had to do
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replacing Drum Roller wheel(s)
  #1 (permalink)
Old 05-03-2013, 09:01 AM
Junior Member
IAMPCBOB is on a distinguished road
Default Replacing Drum Roller wheel(s)
Model Number: LDG8304AAE   Brand: Maytag   Age: More than 10 years
This is the first time I've had to replace a squeeky wheel on this unit, but I had to do it on an older unit. The intructions tell you to ''remove the split retaining ring' for which you need a special ($15-20) tool, that you may only need once. After skinning all my knuckles, because I don't HAVE one of those tools, I got smart. Notice that the wheel is mounted to a small bracket, one on each side of the drum at the rear of the cabinet. Using a half inch box end wrench remove the nut on the back of this bracket and pull the wheel and the shaft right out. Lay it on a work table and you can slide the wheel and the old washers right off! Clean the shaft and oil it, placing a new plastic washer on the shaft, slide the new wheel onto the shaft, putting a drop or two of oil on the shaft. Work this around a few times to be sure it turns freely and place the second plastic washer on the shaft. This puts a washer on each side of the wheel. Notice that you didn't even have to touch the split retaining ring! Place the wheel and shaft back in position on the mounting bracket and start the nut from behind. Mine didn't want to start the threads until I turned the nut around. Tighten it as snug as you can get it. The whole job took, maybe, 5-10 minutes, with no more skinned knuckles. Maybe this will save someone else's knuckles.
Related Models
Maytag LDG8304AAE DRYER- GAS
Maytag LDG8304AAL DRYER- GAS
Maytag LDG8304AAM DRYER- GAS
Maytag LDG8404AAE DRYER- GAS
Maytag LDG8404AAL DRYER- GAS
Maytag LDG8404AAM DRYER- GAS
Maytag LDG8404ABE DRYER- GAS
Maytag LDG8406AAE DRYER- GAS
Maytag LDG8406AAM DRYER- GAS
Maytag LDG8406ABE DRYER- GAS
Maytag LDG8410 DRYER- GAS
Maytag LDG8410AAE DRYER- GAS
Maytag LDG8410AAL DRYER- GAS
Maytag LDG8410AAW DRYER- GAS
Maytag LDG8410ABE DRYER- GAS
Maytag LDG8410ABL DRYER- GAS
Maytag LDG8410ABW DRYER- GAS
Maytag LDG8414AAE DRYER- GAS
Maytag LDG8414AAL DRYER- GAS
Maytag LDG8414AAM DRYER- GAS
Maytag LDG8416AAE DRYER- GAS
Maytag LDG8416AAM DRYER- GAS
Maytag LDG8420 DRYER- GAS
Maytag LDG8420AAL DRYER- GAS
Maytag LDG8420AAW DRYER- GAS
Maytag LDG8420ABL DRYER- GAS
Maytag LDG8420ABW DRYER- GAS
Maytag LDG8424AAE DRYER- GAS
Maytag LDG8424AAL DRYER- GAS
Maytag LDG8424AAM DRYER- GAS
Maytag LDG8424ABE DRYER- GAS
Maytag LDG8426AAE DRYER- GAS
Maytag LDG8426AAM DRYER- GAS
Maytag LDG8426ABE DRYER- GAS
Admiral LDG8426AGE DRYER- GAS
Admiral LDG8426EGE DRYER- GAS
Admiral LDG8426GGE DRYER- GAS
Maytag LDG8500 DRYER- GAS
Maytag LDG8500AAL DRYER- GAS
Maytag LDG8500AAW DRYER- GAS
Maytag LDG8506AAE DRYER- GAS
Maytag LDG8506AAM DRYER- GAS
Maytag LDG8600 DRYER- GAS
Maytag LDG8600AAL DRYER- GAS
Maytag LDG8600AAW DRYER- GAS
Maytag LDG8600ABL DRYER- GAS
Maytag LDG8600ABW DRYER- GAS
Maytag LDG8604AAE DRYER- GAS
Maytag LDG8604AAL DRYER- GAS
Maytag LDG8604AAM DRYER- GAS
Maytag LDG8606AAE DRYER- GAS
Maytag LDG8606AAM DRYER- GAS
Maytag LDG8616AAE DRYER- GAS
Maytag LDG8616AAM DRYER- GAS
Maytag LDG8624AAE DRYER- GAS
Maytag LDG8624AAL DRYER- GAS
Maytag LDG8624AAM DRYER- GAS
Maytag LDG8626AAE DRYER- GAS
Maytag LDG8626AAM DRYER- GAS
Maytag LDG8704AAE DRYER- GAS
Maytag LDG8704AAL DRYER- GAS
Maytag LDG8704AAM DRYER- GAS
Maytag LDG8706AAE DRYER- GAS
Maytag LDG8706AAM DRYER- GAS
Maytag LDG8804AAE DRYER- GAS
Maytag LDG8804AAL DRYER- GAS
Maytag LDG8804AAM DRYER- GAS
Maytag LDG882 DRYER- GAS
Maytag LDG8824AAE DRYER- GAS
Maytag LDG8824AAL DRYER- GAS
Maytag LDG8824AAM DRYER- GAS
Maytag LDG8904AAE DRYER- GAS
Maytag LDG8904AAL DRYER- GAS
Maytag LDG8904AAM DRYER- GAS
Norge LDG9127A DRYER- GAS
Norge LDG9127H DRYER- GAS
Norge LDG9127W DRYER- GAS
Maytag LDG9206AAE DRYER- GAS
Maytag LDG9206AAM DRYER- GAS
Maytag LDG9206ABE DRYER- GAS
Maytag LDG9304AAE DRYER- GAS
Maytag LDG9304AAL DRYER- GAS
Maytag LDG9304AAM DRYER- GAS
Maytag LDG9304ABE DRYER- GAS
Maytag LDG9304ABM DRYER- GAS
Maytag LDG9306AAE DRYER- GAS
Maytag LDG9306AAM DRYER- GAS
Maytag LDG9306ABE DRYER- GAS
Maytag LDG9306ABM DRYER- GAS
Maytag LDG9314AAE DRYER- GAS
Maytag LDG9314AAL DRYER- GAS
Maytag LDG9314AAM DRYER- GAS
Maytag LDG9316AAE DRYER- GAS
Maytag LDG9316AAM DRYER- GAS
Maytag LDG9334AAE DRYER- GAS
Maytag LDG9334AAL DRYER- GAS
Maytag LDG9334AAM DRYER- GAS
Maytag LDG9606AAE DRYER- GAS
Maytag LDG9606AAM DRYER- GAS
Maytag LDG9606ABE DRYER- GAS
Maytag LDG9606ABM DRYER- GAS
Maytag LDG9700 DRYER- GAS
Maytag LDG9700AAL DRYER- GAS
Maytag LDG9700AAW DRYER- GAS
Maytag LDG9700ABL DRYER- GAS
Maytag LDG9700ABW DRYER- GAS
Maytag LDG9701AAL DRYER- GAS
Maytag LDG9701AAW DRYER- GAS
Maytag LDG9701ABL DRYER- GAS
Maytag LDG9701ABW DRYER- GAS
Maytag LDG9800 DRYER- GAS
Maytag LDG9800AAL DRYER- GAS
Maytag LDG9800AAW DRYER- GAS
Maytag LDG9800ABL DRYER- GAS
Maytag LDG9800ABW DRYER- GAS
Maytag LDG9801AAL DRYER- GAS
Maytag LDG9801AAW DRYER- GAS
Maytag LDG9801ABL DRYER- GAS
Maytag LDG9801ABW DRYER- GAS
Maytag LDG9804AAE DRYER- GAS
  #2 (permalink)
Old 05-03-2013, 09:06 AM
Junior Member
Default Ignitors are FRAGILE!!
I just broke another one trying to fit it into position! They are SO fragile. It occurs to me that if they had a metal sleeve fitted over the actual ignitor part that gets hot, maybe with a few holes to allow the gas and air to circulate, they would have enough protection to prevent casual bumps, etc. from breaking them. I know, professional repairers probably don't have this problem, but all of us NON-professionals DO. Since this site is probably used at least 50% by us non-pros this is important.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum Roller grinded down ccaid Dryer Repair 0 01-29-2012 04:56 PM
Drum Roller Replacement BobMM Dryer Repair 1 05-12-2009 06:14 AM
Dryer drum roller welder01 Dryer Repair 1 04-17-2009 08:59 AM
How to replace drum roller RichG Dryer Repair 3 03-30-2009 04:09 AM
