Discuss
Gas Dryer - only heats at beginning of cycle
 in
Dryer Repair
Hello, I have a gas dryer that only ignites the heat flame when the cycle has started but it does
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer - only heats at beginning of cycle
  #1 (permalink)
Old 04-29-2013, 09:46 AM
Junior Member
animateme is on a distinguished road
Default Gas Dryer - only heats at beginning of cycle
Brand: Whirlpool   Age: 5 - 10 years
Hello,
I have a gas dryer that only ignites the heat flame when the cycle has started but it does not ignite at all during the rest of the cycle. The igniter does light up but from what I see the gas valve is not opened up and therefore, no flame.
I removed and checked the Coils (solenoids) and based on these instructions -> http://appliancejunk.com/blog/2010/0...s-valve-coils/ , the coils are fine as they give the right Ohm readings.
I also checked the Flame Sensor and this does show continuity, so it seems to be fine.
If the Flame Sensor and the Coils are good, what else could be causing the flame to ignite only once at the beginning of the cycle but not afterwards?
Thanks in advance for any suggestions provided.
  #2 (permalink)
Old 04-30-2013, 10:24 AM
Junior Member
Default
In case anyone is interested and reads this, I replaced the coils and that solved the problem. So, from this, I can see that even though the coils measure the right Ohms, it does not necessarily mean that they are good.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Monogram overflowing at beginning of cycle mobial Dishwasher Repair 1 03-04-2012 02:29 PM
dryer heats on only one cycle sbraun Dryer Repair 1 11-16-2011 09:21 AM
Dryer heats on timed cycle but not on sensor cycle Richlittleton Dryer Repair 0 08-29-2011 09:33 AM
ge gas dryer heats once at beginning of cycle fish4800 Dryer Repair 0 07-28-2009 01:25 PM
Dryer heats thru first cycle, then no more sharkster Dryer Repair 3 07-30-2008 06:11 PM
