Discuss
dryer is making noise
 in
Dryer Repair
hello i am having a problem with my dryer,it is making noise anytime i put heavy loads and it is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer is making noise
  #1 (permalink)
Old 04-28-2013, 12:43 PM
Junior Member
phil1 is on a distinguished road
Default dryer is making noise
Brand: Whirlpool   Age: 1 - 5 years
hello i am having a problem with my dryer,it is making noise anytime i put heavy loads and it is not the belt because it was changed recently, maybe a few months ago.can anyone please help and give me there opinions on what it can be. Thank you
  #2 (permalink)
Old 04-29-2013, 03:47 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Also it depends on what kind of noise.
Sine the noise is dependent of load weight it is probably related to the drum support parts.
Many units use glides (teflon/plastic strips) to support the front of the drum.
A scraping noise is often an indicator that they need replacing.
Most Whirlpool units use support wheels for the back of the drum. Often a thumping noise is an indicator that they are shot. But may also be squeaking etc. if the wheel bearing or shaft are worn.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My GE Dryer is making a squealing noise John nut Dryer Repair 3 02-04-2013 10:28 AM
Dryer making Bad noise kingdomkid Dryer Repair 1 06-15-2011 12:32 PM
Dryer making noise but won't go on DRAGONFLY1 Dryer Repair 0 04-01-2011 04:18 PM
Dryer making LOUD noise? Cigggy Dryer Repair 0 02-05-2010 09:15 AM
Dryer Making Noise eperdue Dryer Repair 0 11-24-2007 10:22 AM
