Discuss
15 yr htpt heating problem
 in
Dryer Repair
I have a 15 yr old sensi dry hotpoint dryer. A year ago the timed cycle stop drying - it tries
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » 15 yr htpt heating problem
  #1 (permalink)
Old 02-06-2008, 05:57 PM
mike sentiff mike sentiff is offline
Junior Member
mike sentiff is on a distinguished road
Lightbulb 15 yr htpt heating problem
Model Number: DLL2450Rwlh   Brand: Hotpoint   Age: More than 10 years
I have a 15 yr old sensi dry hotpoint dryer. A year ago the timed cycle stop drying - it tries but it does not heat (once in great while it will) but the sensi dry still worked
Now on sensi dry the first 4/5 loads dry great then the next 2 are sort of damp then the next 2 are good then the rest of the loads are wet- maybe it drys them maybe not
Checked the vent -clear, check continuety on thermostat-ok - checked the coils - @ 1300-1400 ohms - ok. turn on the dryer and
The ignitor glows on @ 10 seconds later the flame comes on (ignitor goes out) heATS 2/3 minutes - flame out and we repeat this cycle again once the dryer cools off.
I have no clue at this time- any help or ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 06:54 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Replace the gas valve coils, a common problem with these syptoms.
__________________
  #3 (permalink)
Old 02-07-2008, 06:16 AM
Junior Member
Default 15 yr old htpt
Rich
Thanks for the help - it looked like i was going in that direction --
Even though both coils read 1300 ohms That is a false reading
and should i replace both of them
Mike
  #4 (permalink)
Old 02-07-2008, 09:20 AM
Senior Expert
APP Volunteer
Default
Resistance readings are useless,they will not show shorted turns. They come as a pair anyway, so just replace them.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
heating problem techdowe Dryer Repair 1 01-27-2008 07:04 PM
Heating Problem greenhead88 Oven Repair (including Ranges and Cooktops) 0 01-19-2008 01:43 PM
Heating Level Problem Scott8088 Microwave Repair 0 01-18-2008 08:56 AM
Heating Problem Lynn Wachter Oven Repair (including Ranges and Cooktops) 3 12-11-2007 12:32 PM
Gas Dryer Heating Problem RARMSTRONG@ADELPHIA.NET Dryer Repair 1 12-10-2007 01:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
