Discuss
kenmore elite he3 needs new belt - replace from back?
 in
Dryer Repair
After seeing another post this morning, am I correct in reading that it is easier to change belt from back?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » kenmore elite he3 needs new belt - replace from back?
  #1 (permalink)
Old 04-22-2013, 06:50 AM
Junior Member
teedee is on a distinguished road
Default kenmore elite he3 needs new belt - replace from back?
Model Number: 110.82822102   Brand: Kenmore   Age: 5 - 10 years
After seeing another post this morning, am I correct in reading that it is easier to change belt from back? I know it is a real pain to take apart to the front and can't get it all apart.
front panel attached to bulkhead and didn't come apart like video said.
Can anyone confirm that this is a good way to replace belt? Thank you. I have tech sheet(took it out of machine) when trying to figure this out.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 04-22-2013, 04:57 PM
Senior Member
scott5495 is on a distinguished road
Default new belt
remove the back panel. put the belt around the motor shaft first and then on the large pulley.
  #3 (permalink)
Old 04-22-2013, 08:41 PM
Junior Member
Default
Quote:
am i able to replace drum support rollers to stop the rattling? It doesn't squeal - just sort of rhythmically makes noise - bmm -mmm-mmm-mmm-mm. the drum has lots of rubber from the rollers on the outside.
  #4 (permalink)
Old 04-23-2013, 04:39 AM
Senior Member
Default drum supports
sounds very reasonable. most likely the cause of the rumble because the center bearing of the roller is made from a material that will wear out faster than the shaft, to protect the shaft. replace, especially if rubber is beginning to deteriorate.
  #5 (permalink)
Old 04-23-2013, 05:25 AM
Junior Member
Default
okay 1 more thing. the machine sounds like it is trying to shake itself apart does that still sound like the rollers? to get to replace belt, i have to take a silver cover off something in the back that rollers are attached to to be able to get around anything. hmm have to figure this out... front or back replacement
  #6 (permalink)
Old 04-23-2013, 10:08 AM
Senior Member
Default he3 dryer
at work now. est. will research and post again tonight. we will get there.
  #7 (permalink)
Old 04-23-2013, 03:14 PM
Senior Member
Default dryer belt
i am sending you a link on how to correctly disassemble and reassemble your dryer. https://secured.whirlpool.com/Servic...LE/Duetdry.pdf
  #8 (permalink)
Old 04-24-2013, 09:22 PM
Junior Member
Default
thank you for link. I am just seeing it now, but SUCCESS! I replaced the belt and the rear drum rollers. Opened the machine from the front and replaced rollers and belt. However, couldn't reach to thread the belt. closed machine and opened the back then threaded the belt. Never told hubby I was doing this. He was impressed, I was proud, and I saved us money. BTW hardest thing was detaching stupid wire harnesses!
BTW Scott, you were right about rollers. the metal center ring of one of the rollers was warped and out of shape, and it wasn't attached to plastic/rubber of the roller. I vacuumed up lots of metal and rubber dust. That was the issue but already bought belt so replaced it also. The dryer is so quiet it seems weird!
  #9 (permalink)
Old 04-25-2013, 04:24 AM
Senior Member
Default belt
glad i could help. happy happy happy
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore elite he3 disassembly/belt issue teedee Dryer Repair 3 04-24-2013 09:13 PM
Access Belt Switch on Kenmore Elite mrmac Dryer Repair 1 02-27-2012 04:47 PM
Kenmore Elite HE5 Gas Dryer Needs New Belt PACUNurse Dryer Repair 5 11-09-2011 11:00 PM
how to replace belt on kenmore stackable dryer john buckner Dryer Repair 2 09-18-2010 02:13 PM
How do you take the back off a Kenmore Elite dryer> manks Dryer Repair 1 09-12-2009 09:22 PM
