Discuss
LG worked fine but now won't run at all
 in
Dryer Repair
I disassembled my dryer to replace one of the rear tub roller assemblies. I was very careful and double-checked to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » LG worked fine but now won't run at all
  #1 (permalink)
Old 04-22-2013, 01:41 AM
Junior Member
towski7 is on a distinguished road
Question LG worked fine but now won't run at all
Model Number: DLE3777W   Brand: -other-   Age: 5 - 10 years
I disassembled my dryer to replace one of the rear tub roller assemblies. I was very careful and double-checked to be sure that all connectors were hooked back up properly. Tried it after reassembly and it beeps and acts like it is working but motor does not turn. It literally worked a few hours prior to this. Checked the door switch an it is working properly. Don't want to have to spend 120 bucks on a motor if that's not the problem. Any ideas for how to troubleshoot the problem would be much appreciated. If more info is needed from me, please let me know. Thanks for your assistance.
Related Models
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2900MAL Gas dryer
General Electric DLL2900MBL Gas dryer
  #2 (permalink)
Old 04-22-2013, 07:11 PM
Senior Member
scott5495 is on a distinguished road
Default lg
first i would double check the wiring. make sure the connections at the motor are on tight. it probably is not the motor, since it was working before. iv'e done this for over 30 years and i can still miss a wire now and then. once you check this, if it doesn't work, give me a little more information
  #3 (permalink)
Old 04-22-2013, 07:47 PM
Junior Member
Default
Thanks Scott! Will do!
  #4 (permalink)
Old 04-26-2013, 07:12 PM
Junior Member
Smile
It must have been a loose connection after all. I disconnected all of the connectors from the control panel and then reconnected them and now it works like new again. Thanks for the suggestion! Saved me at least a hundred bucks and a lot of wasted time! Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag dryer worked fine then a few hours later wont turn on snooki Dryer Repair 2 12-02-2010 05:44 AM
worked fine yesterday david03 Oven Repair (including Ranges and Cooktops) 1 11-26-2010 06:54 AM
Installed Compressor Start Device Kit. Worked fine for 3 minutes. rballeng Refrigerator & Freezer Repair 3 10-27-2010 04:06 AM
worked just fine, then ... nothing tgkid Dishwasher Repair 1 03-03-2010 12:55 PM
Old but still worked well roadsendmom Refrigerator & Freezer Repair 2 12-19-2007 07:04 AM
