Discuss
MAYTAG MDE4000AYW wont heat
 in
Dryer Repair
I have a MAYTAG MDE4000AYW Dryer - Ele It will not heat I have downloaded the service manual and wiring
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » MAYTAG MDE4000AYW wont heat
  #1 (permalink)
Old 10-05-2009, 03:08 PM
Junior Member
Ono Nadagin is on a distinguished road
Default MAYTAG MDE4000AYW wont heat
Model Number: MDE4000AYW   Brand: Maytag   Age: 5 - 10 years
It will not heat
I have downloaded the service manual and wiring diagram and schematics from the post on this forum dedicated to my dryer
The heating element was not an open circuit
The high limit thermostat was not an open circuit
The regulating thermostat was not an open circuit
Now here is where I start to get in over my head a lil
I thought it was the temperature selection switch was the problem as when I tested for continuity(meter set to 200 ohms) between where the white white terminal and the rest of the wire terminals while sliding the switch between the positions on the switch, I got no readings.
So I assumed(always gets me in trouble) that it was the source of the non heating problem. I took this switch to the appliance parts house near me and the man there could not get continuity either but he did not have the replacement there to test against to compare readings to judge whether or not the temperature select switch is the problem child.
He told me he would have to order it and then I wouldn't be able to test it before I bought it... He also then told me he thought it was probably the timer switch as thats what he sells the most of for this model when it is a heating issue.
So now I am here asking questions after lurking for a few days trying to get it done with out troubling you nice folks
So I am now at your mercy
Thanks in advance for any and all help or suggestions
Ads By Google
Related Models
Maytag MDE4000AYW DRYER- ELE
Maytag MDE4000AZQ DRYER- ELE
Maytag MDE4000AZW DRYER- ELE
Maytag MDE4057AYQ DRYER- ELE
Maytag MDE4057AYW DRYER- ELE
Frigidaire MDE436RBD0 Frg(v2) / 27 " Electric Dryer
Frigidaire MDE436RBD1 Wwh(v4) / Electric Dryer
Frigidaire MDE436RBD2 Frg(v3) / Electric Dryer
Frigidaire MDE436RBW0 Tap(v10) / 27 " Electric Dryer
Frigidaire MDE436RBW1 Wwh(v5) / Electric Dryer
Frigidaire MDE436RBW2 Frg(v4) / Electric Dryer
Frigidaire MDE436RBWD0 Gib(v14) / 27 " Electric Dryer
Frigidaire MDE436RBWW0 Frg(v1) / 27 " Electric Dryer
Frigidaire MDE436RED0 Frg(v1) / Electric Dryer
Frigidaire MDE436RED1 Frg(v1) / Electric Dryer
Frigidaire MDE436REW0 Frg(v2) / Electric Dryer
Frigidaire MDE436REW1 Frg(v2) / Electric Dryer
Maytag MDE4658AYW DRYER- ELE
Maytag MDE4806AYW DRYER- ELE
Maytag MDE4806AZW DRYER- ELE
Maytag MDE4916AYA DRYER- ELE
Maytag MDE4916AYW DRYER- ELE
Maytag MDE4916AZW DRYER- ELE
Maytag MDE5000AYQ DRYER- ELE
Maytag MDE5000AYW DRYER- ELE
Maytag MDE5000AZW DRYER- ELE
Maytag MDE508DAYK DRYER- ELE
Maytag MDE508DAYW DRYER- ELE
Frigidaire MDE546RED0 Frg(v1) / Electric Dryer
Frigidaire MDE546RED1 Frg(v1) / Electric Dryer
Frigidaire MDE546RES0 Frg(v2) / Electric Dryer
Frigidaire MDE546RES1 Frg(v2) / Electric Dryer
Frigidaire MDE546RET0 Frg(v3) / Electric Dryer
Frigidaire MDE546REW0 Frg(v4) / Electric Dryer
Frigidaire MDE546REW1 Frg(v3) / Electric Dryer
Maytag MDE5500AYQ DRYER- ELE
Maytag MDE5500AYW DRYER- ELE
Maytag MDE5500AZQ DRYER- ELE
Maytag MDE5500AZW DRYER- ELE
Maytag MDE5806AYK DRYER- ELE
Maytag MDE5806AYW DRYER- ELE
Maytag MDE5806AZK DRYER- ELE
Maytag MDE5806AZW DRYER- ELE
Maytag MDE5960AYW DRYER- ELE
Maytag MDE6000AUW DRYER- ELE
Maytag MDE6000AYQ DRYER- ELE
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
  #2 (permalink)
Old 10-05-2009, 04:25 PM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
Sometimes if you is real carefull you can file down the arced points inside the timer.
Here is a burnt contact:
Click on pic to enlarge
Sometimes you can file that contact down and go some more. This one looks fileable.
I have seen em burnt slap up nothing left to file down.
  #3 (permalink)
Old 10-05-2009, 04:43 PM
Junior Member
Default
So you agree that it is probably the timer?
  #4 (permalink)
Old 10-05-2009, 05:03 PM
Junior Member
Default
OK so I popped the timer open and there is one point that is burnt a fair lil amount on the leading contact edge I will hunt down my points files and give it a shot.
Now having said that I was unaware that when I pulled on the cover of the timer after unscrewing it that I would pull a cam lobe assembly out with it I didnt see the tiny retaining clip holding the plate to the shaft of the cam assembly ..
If I would have known I would have witness marked the flat edge of the shaft to the plate to mark its position so I could get the cams back into the case in the proper location... Is there a certain way it must go back in?.. how to you get it set to the default off position.. will I be able to drop it in and rotate it until the cams and not engaging the copper points bars?
  #5 (permalink)
Old 10-05-2009, 05:16 PM
Senior Expert
APP Volunteer
Default
You gotta remove the retainer clip from the shaft and position the cam inside then ease the plate back over. The clip does not need to be on there it is just a mechanic stopper.
You gotta ask yourself how do they do it at the factory? That retainer is the last thang on to prevent tampering.Now would we tamper?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag oven wont heat above 300 degrees mello Oven Repair (including Ranges and Cooktops) 0 12-10-2009 07:46 PM
Maytag gas dryer wont heat nickn Dryer Repair 0 10-06-2009 06:14 PM
maytag stove element wont heat up fishnshaq Oven Repair (including Ranges and Cooktops) 1 05-02-2009 03:07 PM
clothes dryer wont heat timer wont work tampee Dryer Repair 2 01-17-2009 09:53 AM
maytag neptune wont heat rhughes200 Dryer Repair 5 11-26-2008 04:12 AM
