Discuss
Sometimes dryer will hum and not tumble
 in
Dryer Repair
We have a LG electric tumble dryer. Sometime when pressing the start button the dryer will hum and not tumble.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Sometimes dryer will hum and not tumble
  #1 (permalink)
Old 04-17-2013, 08:26 AM
Junior Member
Will2k is on a distinguished road
Default Sometimes dryer will hum and not tumble
Model Number: DLE8377WM   Brand: -other-   Age: 5 - 10 years
We have a LG electric tumble dryer. Sometime when pressing the start button the dryer will hum and not tumble. Two things get it working again normally:
1. Turn the drum by hand during the humming to sett it tumbling.
2. Unplug it and leave it for several hours, and then it restarts normally.
Troubleshooting steps taken so far:
Disassembled the dryer and vacuumed out all the lint around the components.
Checked the belt. It's not worn.
Checked the blower fan for debris and that it spins freely. No debris, spins freely.
Checked the belt tension pully. It spins freely.
Checked the rollers. They spin freely.
We're puzzled as to the cause of this intermittent problem.
A bad motor? A bad control board?
Any ideas welcome.
Related Models
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2900MAL Gas dryer
General Electric DLL2900MBL Gas dryer
General Electric DLL3280SBLWH Gas dryer
General Electric DLL3480SBLAD Gas dryer
General Electric DLL3480SBLWH Gas dryer
General Electric DLL3680SBLAD Gas dryer
General Electric DLL3680SBLWH Gas dryer
General Electric DLL3680SBLWW Gas dryer
General Electric DLL3880SBLAD Gas dryer
General Electric DLL3880SBLWH Gas dryer
General Electric DLL3880SBLWW Gas dryer
General Electric DLL3980SAM Gas dryer
General Electric DLL3980SBM Gas dryer
General Electric DLL6850AAL Electric dryer
General Electric DLL6850ABL Electric dryer
  #2 (permalink)
Old 04-17-2013, 01:59 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Based on the information you provided the motor is bad and should be replaced.
The motor Part number: AP4438218
Here are the breakdown diagrams and parts for LG DLE8377WM - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-29-2013, 01:14 PM
Junior Member
Default
Update,
Today dryer wouldnt tumble. Removed lid to find belt turning and the drum slipping beneat the belt. Is this is a worn belt? Also noticed the belt had moved toward front of drum away from original alignment on the drum. Once the belt pushed back to its original spot the drum tumbled and all seems fine now.
Is the belt worn-out?
What causes the belt to move out of position?
  #4 (permalink)
Old 04-29-2013, 02:52 PM
Expert
Default
Hi.
You should check the idler pulley assembly. The belt most likely is OK, but if you are replacing the pulley change the belt also.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer want tumble derrick 69 Dryer Repair 0 08-03-2012 05:27 PM
dryer won't tumble newman96 Dryer Repair 3 03-10-2010 03:42 PM
dryer want tumble damane Dryer Repair 1 12-01-2009 09:17 AM
Dryer won't tumble stacyvelazco Dryer Repair 6 03-18-2008 12:55 PM
dryer won't tumble 4given1 Dryer Repair 0 12-29-2007 12:12 PM
