gtmarcelo
#1 Posted : Tuesday, April 16, 2013 4:10:07 PM(UTC)
gtmarcelo
No heating in the dryer. Heating element has broken element. Tested with ohm meter and no continuity in the terminal connections. This element needs to be replaced. The problem is how to take out element from the heater housing ? confused:
#2 Posted : Wednesday, April 17, 2013 4:30:13 PM(UTC)
Hello,
You have to remove the heater box first.
Remove the rear cover. Remove the screw that secures the strap spring at the top of the box. Remove the wire leads to the hi-limit thermostat and the heat element. Lift the box off its supports. remove one retaining screw at the bottom of the heater box. Pull the element out through the bottom of the heater box.
In order to install the new elemnt you may need two additional connecting wires which should be ordered separately.
- The heating element Part number: 4391960
- The connecting wire Part number: 279457
Part number: 279457
gtmarcelo
#3 Posted : Thursday, April 18, 2013 9:16:05 AM(UTC)
gtmarcelo
Gene,
Thank you so much to my question. This is very helpfull and make my life easier to fix my dryer. Although this dryer is 23 years old it still give good service. Gene you are a very good man. Again thank you so much. :) :)
Gil Marcelo
#4 Posted : Thursday, April 18, 2013 10:44:59 AM(UTC)
You are welcome Gil. Thank you for your good words. Keep us posted.
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
