Discuss
Need more help with dryer heating problems
 in
Dryer Repair
PROBLEM - The dryer stopped heating. I checked for the continuity of the heating element – 10.3 ohms, high heat
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Need more help with dryer heating problems
  #1 (permalink)
Old 04-12-2013, 05:53 AM
Junior Member
Steves9411 is on a distinguished road
Default Need more help with dryer heating problems
Model Number: 110.60902990   Brand: Kenmore   Age: 5 - 10 years
PROBLEM - The dryer stopped heating. I checked for the continuity of the heating element – 10.3 ohms, high heat thermostat – 0.3 ohms, thermo cut-off fuse – no continuity, cycling thermostat – 0.3 ohms, and the non-resettable thermo fuse – 0.3 ohms. I discovered that thermal cut-off fuse had no continuity, so I cleaned all vents and the dryer thoroughly of lint and purchased and installed a new thermal cut-off kit (fuse and high heat thermostat). The thermal cut-off fuse still keeps kicking out. I learned from an appliance repairman on YouTube that if I smack the thermal cut-off fuse flat side down on a hard concrete surface it will reset. Have done this several times to get dryer to heat for short time, but then it goes out again and heating element won’t heat until I reset the thermal cut-off fuse. Any suggestions of what might be wrong?
Note: I installed a new heating element in fall of 2011.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 04-12-2013, 03:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Remove the wires from the heating element terminals and check for continuity between each of the terminals and the ground. If any of the reading is other than ∞, replace the heating element.
- The heating element assembly Part number: 3392537
BTW, it comes with both thermal cut-off and hi-limit thermostats installed.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dryer Heating Problems bill3854 Dryer Repair 0 04-07-2012 11:17 AM
Kenmore 500 series dryer timer/heating problems Davy99 Dryer Repair 3 04-04-2012 03:20 AM
heating problems jackies Dryer Repair 0 04-01-2010 03:58 PM
Dryer heating and ignitor problems clindell Dryer Repair 0 03-23-2010 06:06 PM
dryer starting and heating problems jbcholding Dryer Repair 4 03-15-2008 09:56 PM
