The rear bearing kit I received, mfg#183897, came with a copper disk and the holder part had what looked like a motor brush on it.These were not on the dryer drum at dis-assembly. Is this bearing kit an upgrade to the original part for this model or was the copper disk thrown in to be applied to the WTL models of the same type of dryer? Also, the two drum supports (black, arc shaped, about 4" long) each have the number 1 and 2 respectively on the side. Do these mount in any particular position?(ie.numbers to the front or back or left or right.) When I removed them, I failed to notice their configuration.A small tube of white grease was in the drum support packaging.Is this to be applied to the support surface? Thanks,Lynn
