AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Fridigaire - Dryer Gas Valve Coil Keeps failing (every few months)
My gas valve coils keep failing. i have replaced them twice in the past 6 months. is there anything that would be a likely cause of pre-mature failure? Problem the last two times was no heat. I remove and repalce the coils and it works fine for a few months. I thought maybe the 1st replacement set going bad was just a fluke. Now that the second set went bad I am trying to determine if there is another cause. Frigidaire 5303931775 Coil Kit (gas Valve)-2 Coils - AppliancePartsPros.com
Dryer Repair
