Discuss
met3800tw2 issues
 in
Dryer Repair
At first our washer / dryer stacked combo decided to just stop working in the middle of a load. So
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » met3800tw2 issues
  #1 (permalink)
Old 04-08-2013, 11:03 AM
Junior Member
jrichtman is on a distinguished road
Default met3800tw2 issues
Model Number: met3800tw2   Brand: Maytag   Age: 1 - 5 years
At first our washer / dryer stacked combo decided to just stop working in the middle of a load. So first thing we figured was it over-heated. We waited till the next day and tried again, No power, no light inside dryer drum, nada. So we called our repair guy who came out and checked the power and after about half an hour said it was probably a grounding issue.
Next day I double up our ground wires (now our lights don't flicker woohoo!) but still no washer or dryer. So I dove into manuals and online help and proceeded in testing the thermostats, fuses, everything except the motor since the plastic fan on it is threaded and seams stuck in place, making near impossible to get it out without taking apart the entire machine. I then vacuumed everything off, put it back together and gave it another go (Insanity at it's best) it was a no go.
So just to make sure if I had to call the repair guy again, I went as far as to replace the 30 amp breaker. Well now I thought I had something, The dryer drum light comes on, but now a whole slew of other issues. If I turn the washer on rinse the water starts, but if the dryer door gets shut the washer turns off. The washer also will not go into spin cycle with the dryer door open or closed. So now I have a few gallons of water in the washer and even more confused. I only removed the wires needed to do testing then put them right back so I am pretty sure nothing got switched around.
Any ideas?
Thank in advance.
Related Models
Maytag MET3800TW2 WASHER/DRYER LAUNDRY SYSTEM
Maytag MET8665XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8665XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8665XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8775XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8775XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8775XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MEV41F-10P MWAVE- CNTRTP / STAND ALONE
Maytag MEW5527BAB WALLOVEN- S/C ELE
Maytag MEW5527BAW WALLOVEN- S/C ELE
Maytag MEW5527DDB WALLOVEN- S/C ELE
Maytag MEW5527DDB16 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5527DDS10 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5527DDW WALLOVEN- S/C ELE
Maytag MEW5527DDW16 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5530AAB WALLOVEN- S/C ELE
Maytag MEW5530AAW WALLOVEN- S/C ELE
Maytag MEW5530ACB WALLOVEN- S/C ELE
Maytag MEW5530ACW WALLOVEN- S/C ELE
Maytag MEW5530BAB WALLOVEN- S/C ELE
Maytag MEW5530BAW WALLOVEN- S/C ELE
Maytag MEW5530BCB WALLOVEN- S/C ELE
Maytag MEW5530BCW WALLOVEN- S/C ELE
Maytag MEW5530DDB WALLOVEN- S/C ELE
Maytag MEW5530DDB17 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDB18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDS10 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDW WALLOVEN- S/C ELE
Maytag MEW5530DDW18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5627BAB WALLOVEN- S/C ELE
Maytag MEW5627BAW WALLOVEN- S/C ELE
Maytag MEW5627DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5627DDB16 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5627DDS10 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEA
Maytag MEW5627DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5627DDW16 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630BAB WALLOVEN- S/C ELE
Maytag MEW5630BAW WALLOVEN- S/C ELE
Maytag MEW5630DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5630DDB17 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630DDS10 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5630DDW18 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6527BAB WALLOVEN- S/C ELE
Maytag MEW6527BAC WALLOVEN- S/C ELE
Maytag MEW6527BAQ WALLOVEN- S/C ELE
Maytag MEW6527BAS WALLOVEN- S/C ELE
Maytag MEW6527BAW WALLOVEN- S/C ELE
Maytag MEW6527CAS WALLOVEN- S/C ELE
Maytag MEW6527DDB WALLOVEN- S/C ELE
Maytag MEW6527DDB18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6527DDQ WALLOVEN- S/C ELE
Maytag MEW6527DDS WALLOVEN- S/C ELE
Maytag MEW6527DDS18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6527DDW WALLOVEN- S/C ELE
Maytag MEW6527DDW18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6530AAB WALLOVEN- S/C ELE
Maytag MEW6530AAW WALLOVEN- S/C ELE
Maytag MEW6530ACB WALLOVEN- S/C ELE
Maytag MEW6530ACW WALLOVEN- S/C ELE
Maytag MEW6530BAB WALLOVEN- S/C ELE
Maytag MEW6530BAC WALLOVEN- S/C ELE
Maytag MEW6530BAQ WALLOVEN- S/C ELE
Maytag MEW6530BAS WALLOVEN- S/C ELE
Maytag MEW6530BAW WALLOVEN- S/C ELE
Maytag MEW6530BCB WALLOVEN- S/C ELE
Maytag MEW6530BCW WALLOVEN- S/C ELE
Maytag MEW6530CAS WALLOVEN- S/C ELE
Maytag MEW6530DDB WALLOVEN- S/C ELE
Maytag MEW6530DDB19 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6530DDQ WALLOVEN- S/C ELE
Maytag MEW6530DDS WALLOVEN- S/C ELE
Maytag MEW6530DDS19 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6530DDW WALLOVEN- S/C ELE
Maytag MEW6530DDW20 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6627BAB WALLOVEN- S/C ELE
Maytag MEW6627BAC WALLOVEN- S/C ELE
Maytag MEW6627BAQ WALLOVEN- S/C ELE
Maytag MEW6627BAS WALLOVEN- S/C ELE
Maytag MEW6627BAW WALLOVEN- S/C ELE
Maytag MEW6627CAS WALLOVEN- S/C ELE
Maytag MEW6627DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDB18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6627DDQ WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDS WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDS18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6627DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6627DDW18 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630BAB WALLOVEN- S/C ELE
Maytag MEW6630BAC WALLOVEN- S/C ELE
Maytag MEW6630BAQ WALLOVEN- S/C ELE
Maytag MEW6630BAS WALLOVEN- S/C ELE
Maytag MEW6630BAW WALLOVEN- S/C ELE
Maytag MEW6630CAS WALLOVEN- S/C ELE
Maytag MEW6630DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDB19 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630DDQ WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDS WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDS19 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6630DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW6630DDW20 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW7530WDB01 30" BUILT-IN ELECTRIC OVEN SELF CLEAN CONVECTION (GOLD
Maytag MEW7530WDS01 30" BUILT-IN ELECTRIC OVEN SELF CLEAN CONVECTION (GOLD
Maytag MEW7530WDW01 30" BUILT-IN ELECTRIC OVEN SELF CLEAN CONVECTION (GOLD
Maytag MEW7630WDB01 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Maytag MEW7630WDS01 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Maytag MEW7630WDW01 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Frigidaire MEX731CFS0 Universal/laundry Center
Frigidaire MEX731CFS1 LAUNDRY CENTER
Frigidaire MEX731CFS2 LAUNDRY CENTER
Frigidaire MEX731CFS4 LAUNDRY CENTER
Frigidaire MF18P2 Frg(v1) / 18 " Dishwasher
Frigidaire MF18PA2 Frg(v4) / 18 " Dishwasher
Frigidaire MF18PF2 Frg(v3) / 18 " Dishwasher
Frigidaire MF18PH2 Frg(v2) / 18 " Dishwasher
Frigidaire MF18PW2 Frg(v5) / 18 " Dishwasher
Frigidaire MFC05M0AW0 Frg(v1) / Chest Freezer
  #2 (permalink)
Old 04-25-2013, 10:13 AM
Junior Member
Default Update
After having the repair guy come out again, and once again telling me it was power related I decided to do a bit more testing.
Here is where I am so far.
If I turn the washer on to any settings and pull out the start / stop button, I used spin as my main test. Then Turn the dryer on any cycle (I used cool down since no vent is connected at the moment) Then hit the start button. Both the washer and dryer function.
However, if I open either door, or turn off either the washer with the start / stop switch, both washer and dryer stop. They will start back up again if I press in the washers start / stop button, then press the start button on the dryer.
They will also start automatically if the washer start button is pulled out (start position) and I turn the dryer knob to a run setting.
At this point I am pretty sure it's probably a bad switch or other electrical item inside the unit itself and not a problem of amperage.
Sadly after taking the control panel screws out and lowering it so I could see inside I was unsure which items to test first to keep from throwing money at it till it works.
Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Two Issues alicentexas Washer Repair 1 04-05-2011 05:54 PM
A few issues.. Scriz Dryer Repair 4 09-17-2009 03:46 PM
GE issues Scott Taylor Refrigerator & Freezer Repair 1 09-25-2008 08:48 AM
