Discuss
Frigidaire high pitched squealing
 in
Dryer Repair
Squeals almost constantly while drying. sometimes it stops but it always starts again and it is getting worse. Related Models
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire high pitched squealing
  #1 (permalink)
Old 04-06-2013, 04:03 PM
Junior Member
ladyred1101 is on a distinguished road
Default Frigidaire high pitched squealing
Model Number: LEQ2152ES0   Brand: Frigidaire   Age: 5 - 10 years
Related Models
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ2152HS0 DRYER
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0 DRYER
Whirlpool LEQ5000KQ1 29"ELECTRIC DRYER
Whirlpool LEQ5000KQ2 29"ELECTRIC DRYER
Whirlpool LEQ5000KW1 29"ELECTRIC DRYER
Whirlpool LEQ5000KW2 29"ELECTRIC DRYER
Whirlpool LEQ5000PW0 29"ELECTRIC DRYER
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ6400FS0 DRYER
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0 DRYER
Whirlpool LEQ7000KQ1 DRYER
Whirlpool LEQ7000KQ2 DRYER
Whirlpool LEQ7030KQ0 DRYER
Whirlpool LEQ7030KQ1 RESIDENTIAL DRYER
Whirlpool LEQ7030KQ2 29"ELECTRIC DRYER
Frigidaire LEQ8000FE0 DRYER
Whirlpool LEQ8000HQ0 DRYER
Whirlpool LEQ8000HQ1 DRYER
Whirlpool LEQ8000JQ0 DRYER
Whirlpool LEQ8000JQ1 DRYER
Whirlpool LEQ8000JQ2 DRYER
Whirlpool LEQ8000JQ3 29"ELECTRIC DRYER
Whirlpool LEQ8000JQ4 ELECTRIC DRYER
Whirlpool LEQ8100KQ0 DRYER
Whirlpool LEQ8100KQ1 DRYER
Whirlpool LEQ8100KT0 DRYER
Whirlpool LEQ8100KT1 DRYER
Whirlpool LEQ8611LG0 RESIDENTIAL DRYER
Whirlpool LEQ8611LG1 27"ELECTRIC DRYER
Whirlpool LEQ8611LW0 RESIDENTIAL DRYER
Whirlpool LEQ8611LW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG0 27" ELECTRIC DRYER
Whirlpool LEQ8611PG1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG2 27"ELECTRIC DRYER
Whirlpool LEQ8611PW0 27" ELECTRIC DRYER
Whirlpool LEQ8611PW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PW2 27"ELECTRIC DRYER
Whirlpool LEQ8621PG0 27" ELECTRIC DRYER
Whirlpool LEQ8621PG1 27"ELECTRIC DRYER
Whirlpool LEQ8621PG2 27"ELECTRIC DRYER
Whirlpool LEQ8621PW0 27" ELECTRIC DRYER
Whirlpool LEQ8621PW1 27"ELECTRIC DRYER
Whirlpool LEQ8621PW2 27"ELECTRIC DRYER
Whirlpool LEQ8800JQ0 DRYER
Whirlpool LEQ8800JQ1 DRYER
Whirlpool LEQ8800JT0 DRYER
Whirlpool LEQ8800JT1 DRYER
Whirlpool LEQ8857HQ0 DRYER
Whirlpool LEQ8857HQ1 DRYER
Whirlpool LEQ8857HZ0 DRYER
Whirlpool LEQ8857HZ1 DRYER
Whirlpool LEQ8857JQ0 DRYER
Whirlpool LEQ8857JQ1 DRYER
Whirlpool LEQ8857JT0 DRYER
Whirlpool LEQ8857JT1 DRYER
Whirlpool LEQ8858HQ0 DRYER
Whirlpool LEQ8858HQ1 DRYER
Whirlpool LEQ8858HZ0 DRYER
Whirlpool LEQ8858HZ1 DRYER
Whirlpool LEQ8858JQ0 DRYER
Whirlpool LEQ8858JQ1 DRYER
Whirlpool LEQ8858JT0 DRYER
Whirlpool LEQ8858JT1 DRYER
Whirlpool LEQ8858JZ1 DRYER
Whirlpool LEQ9030PQ0 29"ELECTRIC DRYER
Whirlpool LEQ9030PQ1 29" ELECTRIC DRYER
Whirlpool LEQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9508LG0 RESIDENTIAL DRYER
Whirlpool LEQ9508LW0 RESIDENTIAL DRYER
Whirlpool LEQ9508LW1 29"ELECTRIC DRYER
Whirlpool LEQ9508PG0 29"ELECTRIC DRYER
Whirlpool LEQ9508PG1 29" ELECTRIC DRYER
Whirlpool LEQ9508PW0 29"ELECTRIC DRYER
Whirlpool LEQ9508PW1 29" ELECTRIC DRYER
Whirlpool LEQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9557KT1 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9558KT0 RESIDENTIAL DRYER
Whirlpool LEQ9558KT1 RESIDENTIAL DRYER
Whirlpool LEQ9857LG0 RESIDENTIAL DRYER
Whirlpool LEQ9857LG1 29"ELECTRIC DRYER
Whirlpool LEQ9857LW0 RESIDENTIAL DRYER
Whirlpool LEQ9857LW1 29"ELECTRIC DRYER
Whirlpool LEQ9857PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858LG0 RESIDENTIAL DRYER
Whirlpool LEQ9858LG1 29"ELECTRIC DRYER
Whirlpool LEQ9858LW0 RESIDENTIAL DRYER
Whirlpool LEQ9858LW1 29"ELECTRIC DRYER
Whirlpool LEQ9858PG0 29"ELECTRIC DRYER
Whirlpool LEQ9858PG1 29"ELECTRIC DRYER
Whirlpool LEQ9858PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858PW1 29"ELECTRIC DRYER
Whirlpool LEQ9957KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9957KT0 RESIDENTIAL DRYER
Admiral LER1115AAW RANGE- F/S STD ELE
Whirlpool LER2614BW0 ELECTRIC DRYER
Whirlpool LER2614BW1 ELECTRIC DRYER
Whirlpool LER2614BW2 ELECTRIC DRYER
Whirlpool LER2614DW0 ELECTRIC DRYER
Whirlpool LER2614DW1 ELECTRIC DRYER
Whirlpool LER2614EW0 ELECTRIC DRYER
Whirlpool LER2614EW1 ELECTRIC DRYER
Whirlpool LER2614EW2 ELECTRIC DRYER
Whirlpool LER2614JQ0 ELECTRIC DRYER
Whirlpool LER2614JQ1 ELECTRIC DRYER
Whirlpool LER2614JQ2 29"ELECTRIC DRYER
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB RANGE- S/C F/S ELE
Admiral LER3330AAW RANGE- S/C F/S ELE
Admiral LER3330AAZ RANGE- S/C F/S ELE
  #2 (permalink)
Old 04-08-2013, 03:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire LEQ2152ES0 Dryer - AppliancePartsPros.com
The most common cause on these units is the rear drum support bearing.
If the unit has a access panel to the bearing put a couple drops of oil on it.
If this reduces/eliminates the problem then you know it is a bearing issue, the oil is just a temporary fix/diagnostic.
Sometimes it just needs cleaning and re-greasing.
In your case it sounds like it may need some parts.
Other areas for squealing are the idler roller, the motor bearings or the front support/glides.
__________________
  #3 (permalink)
Old 04-28-2013, 03:12 PM
Junior Member
Default You're Awesome!
First, thank you. Second you were correct.
Notes for anyone preparing to attempt this: I started taking screws out from the back not realizing I really didnt need to. My first suggestion to anyone else is pay attention, take before pictures/notes so you remember where screws go because there are a lot of them! Second, You have to, at least I did, take the two screws from the back holding the top on. then the bottom front panel beneath (you have to either lift it high or lay it on its side to get to the two of them) the door because this holds the door frame on. When you get to the point where you're ready to lift the drum out note the pulley inside because it falls out easily. This is the only reason I had to remove the small back vent panel because it fell off and I had to put it back on. While you're in there stick your hand in the lint trap compartment. You'll be suprised how much lint you remove. I see why dryers catch fire. I am very happy to announce I dried a load of towels faster than I had in a long time and super quietly! Totally loving you denman!! My kids and dog thank you as well the piercing screach was really bad.
  #4 (permalink)
Old 04-29-2013, 03:41 AM
Senior Expert
APP Volunteer
Default
You are welcome.
I am glad to here that you are up and running again.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
  #5 (permalink)
Old 05-23-2013, 05:50 AM
Junior Member
wjbslick is on a distinguished road
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
high pitched squel arczele Dishwasher Repair 3 10-09-2012 04:04 PM
Refrigerator with high-pitched hum bbooks Refrigerator & Freezer Repair 1 01-06-2012 06:31 AM
High pitched squeak rcakelady Dryer Repair 1 09-21-2009 04:35 AM
High pitched squealing noise b428337 Dryer Repair 3 10-06-2008 02:41 PM
high pitched noise Raleigh Dishwasher Repair 1 12-20-2007 06:35 AM
