Dryer initially had intermittently worked and not worked, no heat. I have checked all of the t-stats and thermistor, all check ok.
I am unsure of what the ohm values should be on the heating element they check as follows top to bottom 20 top to middle 20 bottom to middle 40
notes; the unit is clean and unblocked and the power checks good.
Wondering if it is the control board if these heat element readings are ok. The only reference I have found is a generic video that said if the readings were between 0 and 50 it was ok.
thanks in advance!
