Discuss
Kenmore 110.60812990 will not stop
 in
Dryer Repair
Hi. I have a Kenmore electric dryer that dries fine but will not stop because the timer is not advancing.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore 110.60812990 will not stop
  #1 (permalink)
Old 04-05-2013, 12:55 PM
Junior Member
Nykin is on a distinguished road
Default Kenmore 110.60812990 will not stop
Model Number: 110.60812990   Brand: Kenmore   Age: 1 - 5 years
Hi. I have a Kenmore electric dryer that dries fine but will not stop because the timer is not advancing. Even when set on Timed Dry, it will not advance. I can rotate the dial fine. It appears to use the #3976576 timer.
I was wondering how can I test to be sure that the timer is bad?
Is it possible that one of the sensors, like the dryness sensor, is bad and would cause the timer to not advance? If so, how can I test this?
Thank you
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 04-06-2013, 03:02 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Kenmore Dryer 11060812990 - AppliancePartsPros.com
The timer is
Part number: AP3100522
Click on the picture for more info about the timer.
You could test the power across the timer motor. If you have 120 volts and the timer does not advance then it is toast.
Use timed dry when testing.
Also the dryer should be running.
I cannot find a wiring diagram for this unit.
Do you have it?
Often it is stored in the control console.
It is important because on many dryers the power to the timer motor also runs through a set of contacts in the timer.
Be very careful when doing this as there is 240 volts at the timer and it is lethal!!!
Not very likely as on most dryers the power to the timer is direct when in timed dry.
__________________
  #3 (permalink)
Old 04-07-2013, 12:56 PM
Junior Member
Default
Thank you for the reply. I tested the voltage across the timer motor during timed dry and it is receiving 120 V, but not advancing. So I assume the motor in the timer is bad, and I need to replace the timer. I do have the wiring diagram. If you still need it I can upload it, but I assume you don't since the motor is almost certainly the problem.
*EDIT*
After I get this timer fixed, what sort of routine maintenance should I be performing on the dryer? The dryer came with the purchase of a house—is there anything I can do to check that it is in good working order?
  #4 (permalink)
Old 04-08-2013, 02:59 AM
Senior Expert
APP Volunteer
Default
About the only routine maintenance is to check/clean your vent system every year or so.
If you do have a problem that requires you to open up the main cabinet of the unit then check things like the belt, the drum seals, the rear and front drum supports/glides/rollers, the idler wheel, etc.
Also clean the interior including the blower wheel.
Basically give it an overhaul.
__________________
  #5 (permalink)
Old 04-11-2013, 09:29 PM
Junior Member
Default
Thank you for the help. I bought and installed a new timer and the dryer is now working perfectly. I will also be cleaning out the vent system soon. Thank you again for the help.
  #6 (permalink)
Old 04-12-2013, 03:35 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My kenmore has stop making ice!!! ineedhelp52 Refrigerator & Freezer Repair 0 01-16-2013 09:23 PM
Kenmore - doesn't stop or heat. thedrana Dryer Repair 0 07-31-2010 08:23 AM
Kenmore won't stop filling brettcummins Washer Repair 1 01-23-2010 03:48 PM
Kenmore Elite won't stop filling up! Bobby_g Washer Repair 8 09-24-2009 02:05 PM
kenmore 110 series won't stop chzbykr Dryer Repair 7 10-02-2008 06:29 AM
