Discuss
Odd Piece
 in
Dryer Repair
I just bought an older model Frigidaire Laundry Center model GLET104AS1. The washer works fine but the dryer had some
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Odd Piece
  #1 (permalink)
Old 04-02-2013, 09:36 PM
Junior Member
dogseason is on a distinguished road
Default Odd Piece
Model Number: GLET104AS1   Brand: Frigidaire   Age: 5 - 10 years
I just bought an older model Frigidaire Laundry Center model GLET104AS1. The washer works fine but the dryer had some problems that I was aware of. What I do know is the bearing and ball hitch need to be replaced as well as it needs a new belt. However when I took the top panel off I found this semi L shaped black piece of molded plastic laying up top in between the drum and the front panel. I have looked the diagrams over and I do not see a piece that looks like this. It really doesn't even match anything else on the machine that I see. Any ideas of what this piece may be or maybe just an unrelated piece that ended up inside the machine?
Related Models
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLET1142FS1 LAUNDRY CENTER
Frigidaire GLET1142FS2 LAUNDRY CENTER
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1326FW2 FREEZER
Frigidaire GLFC1326FW3 FREEZER
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC1526FW2 FREEZER
Frigidaire GLFC1526FW3 FREEZER
Frigidaire GLFC1526FW4 FREEZER
Frigidaire GLFC1526FW5 FREEZER
Frigidaire GLFC1526FW6 FREEZER
Frigidaire GLFC1526FW7 FREEZER
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2027FW4 FREEZER
Frigidaire GLFC2027FW5 FREEZER
Frigidaire GLFC2027FW6 FREEZER
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW10 FREEZER
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFC2528FW4 FREEZER
Frigidaire GLFC2528FW5 FREEZER
Frigidaire GLFC2528FW6 FREEZER
Frigidaire GLFC2528FW7 FREEZER
Frigidaire GLFC2528FW8 FREEZER
Frigidaire GLFC2528FW9 FREEZER
Frigidaire GLFH1467GW0 FREEZER
Frigidaire GLFH1467GW1 FREEZER
Frigidaire GLFH1767GW1 FREEZER
Frigidaire GLFH1779GW0 FREEZER
Frigidaire GLFH1779GW1 FREEZER
Frigidaire GLFH1779GW2 FREEZER
Frigidaire GLFH17F8HBA FREEZER
Frigidaire GLFH17F8HBB FREEZER
Frigidaire GLFH17F8HBC FREEZER
Frigidaire GLFH17F8HBD FREEZER
Frigidaire GLFH17F8HBF FREEZER
Frigidaire GLFH17F8HBG FREEZER
Frigidaire GLFH17F8HBH FREEZER
Frigidaire GLFH17F8HWA FREEZER
Frigidaire GLFH17F8HWB FREEZER
Frigidaire GLFH17F8HWC FREEZER
Frigidaire GLFH17F8HWD FREEZER
Frigidaire GLFH17F8HWE FREEZER
Frigidaire GLFH17F8HWF FREEZER
Frigidaire GLFH17F8HWG FRIGIDAIRE/FREEZER
Frigidaire GLFH17F8HWH FRIGIDAIRE/FREEZER
Frigidaire GLFH21F8HBA FREEZER
Frigidaire GLFH21F8HBB FREEZER
Frigidaire GLFH21F8HBC FREEZER
Frigidaire GLFH21F8HBD FREEZER
Frigidaire GLFH21F8HBE FREEZER
Frigidaire GLFH21F8HWA FREEZER
Frigidaire GLFH21F8HWB FREEZER
Frigidaire GLFH21F8HWC FREEZER
Frigidaire GLFH21F8HWD FREEZER
Frigidaire GLFH21F8HWE FREEZER
Frigidaire GLFH21F8HWG FREEZER
Frigidaire GLFN1326GW0 FREEZER
Frigidaire GLFN1326GW1 FREEZER
Frigidaire GLFN1326GW2 FREEZER
Frigidaire GLFN1326GW3 FREEZER
Frigidaire GLFU1467FW0 Frigidaire/freezer
Frigidaire GLFU1467FW1 FREEZER
Frigidaire GLFU1467FW2 FREEZER
Frigidaire GLFU1767FW2 Frigidaire/freezer
Frigidaire GLFU1767FW3 Frigidaire/freezer
Frigidaire GLFU1767FW4 Frigidaire/freezer
Frigidaire GLFU1767FW5 FREEZER
Frigidaire GLFU1767FW6 FREEZER
Frigidaire GLFU2067FW2 Frigidaire/freezer
Frigidaire GLFU2067FW3 Frigidaire/freezer
Frigidaire GLFU2067FW4 Frigidaire/freezer
Frigidaire GLFU2067FW5 FREEZER
Frigidaire GLFU2067FW6 FREEZER
Frigidaire GLFU2067FW7 FREEZER
Frigidaire GLFU2067FW8 FREEZER
Frigidaire GLGC30S8ABA Frigidaire/cooktop
Frigidaire GLGC30S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC30S8AQA Frigidaire/cooktop
Frigidaire GLGC30S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8ASA Frigidaire/cooktop
Frigidaire GLGC30S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC30S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSB Frigidaire/gas Cooktop
Frigidaire GLGC30S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S9ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC36S8EBA Frigidaire/gas Cooktop
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Single Piece Shaft kaylee88 Washer Repair 4 03-28-2010 02:19 AM
Broke a piece off my washer clapsadle Washer Repair 3 09-21-2009 09:48 PM
kitchen aid piece of junk at it again..... fumey Refrigerator & Freezer Repair 9 08-10-2009 11:56 AM
How Do i get the back piece off JohnD49 Dryer Repair 1 11-22-2008 01:38 AM
