uncledale1031
#1 Posted : Tuesday, April 2, 2013 10:54:57 AM(UTC)
uncledale1031
Just changed:
Heat element
Hi limit thermostat
Thermostat
After the three changes, still no heat..Now what
#2 Posted : Tuesday, April 2, 2013 11:13:32 AM(UTC)
I cannot tell from the info I can find on this unit whether it is a 240 volt dryer but if it is I would check the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
The motor etc. runs off of 120 volts but the heater requires the full 240 volts.
If OK
If OK
Replaced oven element in 7 year old Whirlpool stove and still no heat (Oven Repair (including Ranges and Cooktops))
by Guest 4/14/2021 2:34:36 PM(UTC)
Replaced oven element and still no heat (Oven Repair (including Ranges and Cooktops))
by Guest 4/14/2021 2:32:26 PM(UTC)
All parts have continuity still no heat (Dryer Repair)
by Goineson 12/9/2017 9:29:35 PM(UTC)
by Goineson 12/9/2017 9:28:56 PM(UTC)
Replaced/tested everything - still no heat - (Dryer Repair)
by Snug Harbor 2/23/2015 7:29:12 AM(UTC)
Checked thermo stats, power source, heating element, still no heat (Oven Repair (including Ranges and Cooktops))
by rickortenblad 4/15/2014 9:10:58 AM(UTC)
Replaced Temp sensor, still no heat (Oven Repair (including Ranges and Cooktops))
by Hypnocrip 2/21/2014 12:34:27 AM(UTC)
GE Replaced Gas Valve Coils - Still no heat (Dryer Repair)
by ScottKr 8/10/2013 10:55:48 AM(UTC)
Replaced heating element and still no heat. (Dryer Repair)
by freqflyer 5/17/2013 7:53:48 AM(UTC)
by Frits6 12/17/2012 4:15:29 PM(UTC)
replace element and tested everything still no heatzs (Oven Repair (including Ranges and Cooktops))
by grmbmg 4/12/2012 9:05:13 PM(UTC)
New Parts and still no Heat!!!! (Dryer Repair)
by larosa00 10/29/2011 5:37:59 PM(UTC)
Everything checking out still no heat? (Dryer Repair)
by max32111 7/10/2011 9:16:57 AM(UTC)
After changing magnatron and diode still no heat (Microwave Repair)
by Srizvi5 4/3/2011 6:05:12 PM(UTC)
Tappan range oven burnt element/replaced/ still no heat (Oven Repair (including Ranges and Cooktops))
by bandit571 2/11/2011 12:56:41 PM(UTC)
