Discuss
Maytag dryer - no heat
 in
Dryer Repair
My Maytag gas dryer just stopped heating. I opened up the front & turned it on & there was no
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag dryer - no heat
  #1 (permalink)
Old 02-05-2008, 04:24 PM
esh esh is offline
Junior Member
esh is on a distinguished road
Default Maytag dryer - no heat
Model Number: MDG7400AWW   Brand: Maytag   Age: 1 - 5 years
My Maytag gas dryer just stopped heating. I opened up the front & turned it on & there was no flame. I'm not sure how to tell wich part it is that is in need of repair.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 02:48 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
There are five major electrical parts involved in the heating process:
1. Hi limit thermostat
2. Cycling thermostat
3. Igniter
4. Flame sensor
5. Gas valve coils
How to find out which part causing the problem?
Pretty simple: all of these parts have to be tested for continuity in the above sequence.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
If any of them is open – it has to be replaced.
Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals.
1. Coil with two terminals should have 1220 ± 50 Ohms
2. Coil with three terminals if held with terminals in upper position:
a) across the left and the middle terminals – 1365 ± 25 Ohms
b) across the left and the right terminals – 560 ± 25 Ohms
- The part number for the hi limit thermostat is AP275754
- The part number for the igniter is AP3464835
- The part number for the flame sensor is AP2910747
- The part number for the gas valve coils kit is AP3094251
- The part number for the cycling thermostat is AP276896
The first four parts are located on or around the gas valve, the cycling thermostat is located on the blower cover.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-06-2008, 08:38 PM
esh esh is offline
Junior Member
Thumbs up Thanks.
Thanks. I will test that. I apreciate you're assistance.
  #4 (permalink)
Old 02-06-2008, 10:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #5 (permalink)
Old 02-10-2008, 07:49 PM
jfairman jfairman is offline
Junior Member
jfairman is on a distinguished road
Default
Gene,
Thanks a million! With the diagrams supplied and an ohm meter I bought many years ago, I diagnosed a broken igniter in my Maytag LDG482. Learned a whole lot about gas dryers in the process, too! I've never opened up a dryer before, but with your easy to follow and clearly written guidance. Done! Fantastic resource!
  #6 (permalink)
Old 02-10-2008, 10:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi jfairman,
I'm glad you were able to fix it.
__________________
  #7 (permalink)
Old 02-11-2008, 04:42 PM
esh esh is offline
Junior Member
Smile looks like it's the Igniter
ohmmeter came in 2 days & it looks like it's the igniter. I just ordered a new one & we'll see what happens. thanks for your help!
  #8 (permalink)
Old 02-15-2008, 12:28 PM
esh esh is offline
Junior Member
Smile Back in business!
Installed the new igniter & it's workig perfectly! Thank you very much for your assistance. I will definitely recomend this site to anyone I know who is having trouble with an appliance. Saved me a lot of money, & I learnt a lot in the proccess. Keep up the good work!
  #9 (permalink)
Old 02-15-2008, 12:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #10 (permalink)
Old 08-02-2008, 01:41 PM
fjpionier fjpionier is offline
Junior Member
fjpionier is on a distinguished road
Default Need some help after reading this thread!
Ok, no heat at all coming from my Maytag Gas Dryer. I did alot of research on the net and found this thread. This is what I did so far.
1. Checked cont on fuse
2. Checked cont on thermostat
3. Checked cont on the coils (both)
4. Checked flame sensor and it gave me a value of 1.?? Would that be the problem
5. Checked Ignitor and got an Ohm reading of 87. From what I read that is ok. I don't see any cracks.
At this point I have hit the wall. Any suggestions before I just go out and buy a new one? I hate to do it.....
- Erich
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag LSG7804AAE Dryer - Won't Heat Up HockeyDave Dryer Repair 4 02-14-2008 01:37 PM
Maytag Dryer- won't heat - testing help please WCWRex Dryer Repair 1 02-05-2008 03:38 AM
Help with Maytag Dryer-won't heat up momto3 Dryer Repair 0 01-23-2008 09:54 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
maytag gas dryer will not heat after initial burn Agustin Dryer Repair 1 08-28-2007 10:48 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
