Discuss
Maytag Dryer, No Heat, What Am I Missing?
 in
Dryer Repair
I have a Maytag dryer that isn't heating up. I have 240 volts at the outlet. The thermostats show continuity.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer, No Heat, What Am I Missing?
  #1 (permalink)
Old 03-28-2013, 05:20 PM
Junior Member
rankins66 is on a distinguished road
Default Maytag Dryer, No Heat, What Am I Missing?
Model Number: LDE9306ACE   Brand: Maytag   Age: 5 - 10 years
I have a Maytag dryer that isn't heating up. I have 240 volts at the outlet. The thermostats show continuity. The heating element shows continuity and 120 volts on each terminal. I don't know what I'm doing wrong. I hope someone can help me. The laundry is piling up.
Related Models
Maytag LDE9306ACE DRYER- ELE
Maytag LDE9306ACM DRYER- ELE
Maytag LDE9306ADE DRYER- ELE
Maytag LDE9306ADM DRYER- ELE
Maytag LDE9306AEE DRYER- ELE
Maytag LDE9314ACE DRYER- ELE
Maytag LDE9314ACL DRYER- ELE
Maytag LDE9314ACM DRYER- ELE
Maytag LDE9314ADE DRYER- ELE
Maytag LDE9316ACE DRYER- ELE
Maytag LDE9316ACM DRYER- ELE
Maytag LDE9316ADE DRYER- ELE
Maytag LDE9334ACE DRYER- ELE
Maytag LDE9334ACL DRYER- ELE
Maytag LDE9334ACM DRYER- ELE
Maytag LDE9334ADE DRYER- ELE
Maytag LDE9606ACE DRYER- ELE
Maytag LDE9606ACM DRYER- ELE
Maytag LDE9606ADE DRYER- ELE
Maytag LDE9606ADM DRYER- ELE
Maytag LDE9606AEE DRYER- ELE
Maytag LDE9700 DRYER- ELE
Maytag LDE9700ACL DRYER- ELE
Maytag LDE9700ACW DRYER- ELE
Maytag LDE9700ADL DRYER- ELE
Maytag LDE9700ADW DRYER- ELE
Maytag LDE9701ACL DRYER- ELE
Maytag LDE9701ACW DRYER- ELE
Maytag LDE9701ADL DRYER- ELE
Maytag LDE9701ADW DRYER- ELE
Maytag LDE9800 DRYER- ELE
Maytag LDE9800ACL DRYER- ELE
Maytag LDE9800ACW DRYER- ELE
Maytag LDE9800ADL DRYER- ELE
Maytag LDE9800ADW DRYER- ELE
Maytag LDE9801ACL DRYER- ELE
Maytag LDE9801ACW DRYER- ELE
Maytag LDE9801ADL DRYER- ELE
Maytag LDE9801ADW DRYER- ELE
Maytag LDE9804ACE DRYER- ELE
Maytag LDE9804ACL DRYER- ELE
Maytag LDE9804ACM DRYER- ELE
Maytag LDE9804ADE DRYER- ELE
Maytag LDE9804ADL DRYER- ELE
Maytag LDE9804ADM DRYER- ELE
Maytag LDE9804AEE DRYER- ELE
Maytag LDE9806ACE DRYER- ELE
Maytag LDE9806ACM DRYER- ELE
Maytag LDE9806ADE DRYER- ELE
Admiral LDE9806GGE DRYER- ELE
Maytag LDE9814ACE DRYER- ELE
Maytag LDE9814ACL DRYER- ELE
Maytag LDE9814ACM DRYER- ELE
Maytag LDE9814ADE DRYER- ELE
Maytag LDE9824ACE DRYER- ELE
Maytag LDE9824ACL DRYER- ELE
Maytag LDE9824ACM DRYER- ELE
Maytag LDE9824ADE DRYER- ELE
Maytag LDE9900 DRYER- ELE
Maytag LDE9900ACL DRYER- ELE
Maytag LDE9900ACW DRYER- ELE
Maytag LDE9900ADL DRYER- ELE
Maytag LDE9900ADW DRYER- ELE
Maytag LDE9900BCL DRYER- ELE
Maytag LDE9900BCW DRYER- ELE
Maytag LDE9900BDL DRYER- ELE
Maytag LDE9900BDW DRYER- ELE
Maytag LDE9904ACE DRYER- ELE
Maytag LDE9904ACL DRYER- ELE
Maytag LDE9904ACM DRYER- ELE
Maytag LDE9904ADE DRYER- ELE
Admiral LDEA100ACL DRYER- ELE
Admiral LDEA100ACW DRYER- ELE
Admiral LDEA100BCE DRYER- ELE
Admiral LDEA100BCM DRYER- ELE
Admiral LDEA200ACE DRYER- ELE
Admiral LDEA200ACL DRYER- ELE
Admiral LDEA200ACM DRYER- ELE
Admiral LDEA200ACW DRYER- ELE
Admiral LDEA300AGE DRYER- ELE
Admiral LDEA300AGL DRYER- ELE
Admiral LDEA300AGW DRYER- ELE
Admiral LDEA300AKE DRYER- ELE
Admiral LDEA400ACE DRYER- ELE
Admiral LDEA400ACL DRYER- ELE
Admiral LDEA400ACM DRYER- ELE
Admiral LDEA400ACW DRYER- ELE
Admiral LDEA500ACE DRYER- ELE
Admiral LDEA500ACL DRYER- ELE
Admiral LDEA500ACM DRYER- ELE
Admiral LDEA500ACW DRYER- ELE
Hoover LDEH200ACV DRYER- ELE
Hoover LDEH200AGV DRYER- ELE
Hoover LDEH200AKV DRYER- ELE
 LDF6810BB Dishwasher
 LDF6810ST Dishwasher
 LDF6810WW Dishwasher
 LDF6920BB Dishwasher
 LDF6920ST Dishwasher
 LDF6920WW Dishwasher
 LDF7810BB Dishwasher
 LDF7810ST Dishwasher
 LDF7810WW Dishwasher
 LDF7811BB Dishwasher
 LDF7811ST Dishwasher
 LDF7811WW Dishwasher
 LDF7932ST Dishwasher
 LDF8812ST Dishwasher
 LDF9810ST Dishwasher
 LDF9932ST Dishwasher
Admiral LDG1000AAE DRYER- GAS
Maytag LDG110 DRYER- GAS
Maytag LDG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
  #2 (permalink)
Old 03-29-2013, 03:46 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Maytag LDE9306ACE - AppliancePartsPros.com
Do you have the wiring diagram for this unit?
Is there 240 volts at the terminal strip in the unit?
Could always be a bad line cord.
The 120 on both sides of the heating coil does not tell you much as Neutral is not part of the heater circuit.
Was the motor running when you measured this?
If yes is there voltage at the heater when the motor is not running but the timer is at mid scale of a manual heating mode?
The below assumes the motor was off when you checked the voltage.
If the timer is set to a heating mode then the L1 (120 volts) voltage is connected thru some timer contacts to one side of the heating coil as long as the cycling thermostat and hi-limit thermostat are OK. So if you see it on one side and the heating coil is OK you will also see it on the other side (the 120 feeds through the heating coil).
It does tell you that the odds are high that the timer, thermostats and heating coil are OK.
If the motor was running when you did the voltage test then you may have been seeing the L2 voltage at the coil.
It is fed to the heater through a centrifugal switch on the motor. This switch closes when the motor gets close to operating speed. It is there to ensure that the heater does not come on till there is air flow.
When you measure with Neutral as the reference you have no way of knowing if you are reading L1 or L2 voltage.
To see if the hater is getting the correct voltage you have to measure across it for 240 volts (L1 and L2 voltage)
So to recap.
If voltage (120) (L1) is there when the motor is Off then odds are there is a problem with the motor's centrifugal switch.
If voltage (120) (L2) is there only when the motor is running then odds are there is a problem with the timer contacts, the cycling thermostat or the high limit thermostat.
I hope I did not confuse you with the above!!
__________________
  #3 (permalink)
Old 03-29-2013, 05:19 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
So to recap.
The motor was running. The terminals were still attached to the heating element. Is this the correct way to check the voltage at the heating element? Or does 120 volts simply pass thru the heating element to the other terminal? Thanks for all of your help. This will point me in the right direction. I will check the voltage again this evening.
  #4 (permalink)
Old 03-29-2013, 09:11 AM
Senior Expert
APP Volunteer
Default
It is one way but it can confuse you.
If the centrifugal switch is bad you will see 120 volts on both sides (L1).
If the circuit through the thermostats is bad you will see 120 volts on both sides (L2).
If everything is OK you will see 120 on both sides L1 on one side and L2 on the other. If the heater is OK then it would heat up because there is 240 across the heating coil.
Yes.
Because Neutral is not part of the heater there is not a circuit path for the 120 so the coil does not drop any voltage.
FYI: Just in case you do not know how the 240 volts is achieved.
Your supply voltage is actually two 120 volt supplies with a common Neutral.
They are 180 degrees out of phase. So when one is at positive 120 volts, the other is at negative 120 volts. Measuring from one to the other then gives you the 240 volts.
You could check the continuity thru the timer and thermostats.
Use the most sensitive meter scale, short the meter leads together before starting so you can see if the meter has any zero offset.
Unplug the unit.
Set the timer to mid scale of a heating cycle.
Place one meter lead on BK (black) (L1) at the timer.
Now measure to the heater coil connectors.
One side should be 0 ohms.
The other should be 8 to 12 ohms (the heater resistance).
__________________
  #5 (permalink)
Old 04-01-2013, 02:34 AM
Junior Member
Default
Yes.
Unplug the unit.
There was a blue wire burned off of the terminal block. The dryer had a new cord on it so I just assumed voltage at the block would be good and didn't check it. My mistake. Thanks for all of your help.
  #6 (permalink)
Old 04-01-2013, 02:45 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Heat - Maytag gas dryer u01tnh00 Dryer Repair 8 03-06-2011 04:44 PM
maytag fridge freezer missing part help! danielle312 Refrigerator & Freezer Repair 5 02-22-2011 04:53 AM
Dryer Timer with one terminal missing guitarkar Dryer Repair 1 02-21-2011 06:00 PM
Maytag Dryer Heat off and on sattamander Dryer Repair 5 12-14-2010 04:46 AM
Missing Wiring on Dryer tboneadam82 Dryer Repair 1 01-04-2010 04:52 AM
