While replacing the drum belt on this dryer my son and I ruined the ribbon cable that connects the front console panel to the other electric panel on the top left inside the dryer.
The Part Number on the ribbon cable WPL PN P/N 8546172 Rev.Rel 0405 Mexico This part number does not come up as a replaceable part anywhere. Yet it is the part that came with the dryer. Not sure what that is about . Not even a replacement part number.
So. I need help figuring out how to get a used one or how to get one made. I assume I need some specs to do this?
All other fuses and thermostats test fine.
Help.
