Please help!
My dryer is heating fine when I don't install its front panel - drying is normal but I do not want to operate this way because it is unsafe.
When I put back front panel and run the dryer, dryer have no heat to dry clothes. I checked exhauted duck and it clear and clean. What part(s) should I check or replace?
Your help will be greatly appreciated.
