Register | FAQ's | New Posts | Today's Posts | Extras |
» Dryer not drying |
![]() Model Number: rex5634pqo Brand: Roper Age: 1 - 5 years
![]() Do i need a heating element or is there another problem? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Hi,
There are a few things that can make your dryer not heat. Voltage to the dryer (240v) if electric. Heating element. Thermo fuse.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
![]() Here are your parts
Replacement parts for WHIRLPOOL REX5634PQ0 | AppliancePartsPros.com Here is the wiring diagram http://www.servicematters.com/docs/w...%208528187.pdf If you put the unit into timed dry and the timer advances you should have 240 volts as the timer on this unit uses 240 volts. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Gas dryer not drying | bkcprice1 | Dryer Repair | 3 | 02-26-2009 02:16 PM |
Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
gas dryer not drying | losanft | Dryer Repair | 0 | 02-03-2008 08:43 AM |
dryer not drying enough | lt3 | Dryer Repair | 5 | 01-04-2008 10:38 AM |
Dryer not drying | sue1759 | Dryer Repair | 5 | 11-02-2007 05:09 PM |
