Discuss
Maytag Gas Solenoid replacement
 in
Dryer Repair
I want to try to replace the Maytag DG309 Gas Dryer Gas Solenoids. I tried to take them apart to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Gas Solenoid replacement
  #1 (permalink)
Old 03-20-2013, 12:38 PM
Junior Member
boulosb is on a distinguished road
Default Maytag Gas Solenoid replacement
Model Number: DG309   Brand: Maytag   Age: More than 10 years
I want to try to replace the Maytag DG309 Gas Dryer Gas Solenoids. I tried to take them apart to see if I could do the job. I took the bracket off the left side solenoids. There are 2 solenoids on this side, stack on top of each other, with a shaft through them. There was also a small black washer with them. I'm not sure of where it goes. I tried putting underneath the bottom solenoid, but then the bracket doesn't fit back on correctly. Does it go between the two solenoids? I would appreciate any help on this. I haven't ordered them yet. I first wanted to see if I could do the job myself. Thanks.
Ads By Google
Related Models
Maytag DG309 Dryer - Gas
Maytag DG30CA Dryer - Gas
Maytag DG30CM Dryer - Gas
Maytag DG30CMD Dryer - Gas
Maytag DG30CT Dryer - Gas
Maytag DG312 Dryer - Gas
Maytag DG312D Dryer - Gas
Maytag DG313 Dryer - Gas
Maytag DG313D Dryer - Gas
Maytag DG31CA Dryer - Gas
Maytag DG31CM Dryer - Gas
Maytag DG31CT Dryer - Gas
Amana DG3240 Washer - Top Loading
Amana DG3250 Washer - Top Loading
Amana DG3261 Washer - Top Loading
Amana DG3280 Washer - Top Loading
Amana DG3281 Washer - Top Loading
Amana DG3291 Washer - Top Loading
Maytag DG32CA Dryer - Gas
Maytag DG32CM Dryer - Gas
Maytag DG32CT Dryer - Gas
Amana DG3300 Washer - Top Loading
Amana DG3331 Washer - Top Loading
Amana DG3341 Washer - Top Loading
Amana DG3350 Washer - Top Loading
Maytag DG33CA Dryer - Gas
Maytag DG33CM Dryer - Gas
Maytag DG34CD Dryer - Gas
Maytag DG34CQ Dryer - Gas
Frigidaire DG350RXD1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG350RXD2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG350RXD3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG350RXW3 Wwh(v2) / 27 " Gas Dryer
Amana DG3630 Washer - Top Loading
Amana DG3680 Washer - Top Loading
Amana DG3681 Washer - Top Loading
Amana DG3800 Washer - Top Loading
Amana DG3801 Washer - Top Loading
Maytag DG382 Dryer - Gas
Amana DG3860 Washer - Top Loading
Amana DG3861 Washer - Top Loading
Frigidaire DG3900ADD1 Frg(v6) / 27 " Gas Dryer
Frigidaire DG3900AWW1 Frg(v5) / 27 " Gas Dryer
Maytag DG4000 Dryer - Gas
Frigidaire DG400AXD1 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400AXD2 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400AXW1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400AXW2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG400EXD4 Wwh(v2) / Gas Dryer
Frigidaire DG400EXD5 Wwh(v3) / Gas Dryer
Frigidaire DG400EXF1 Wwh(v4) / Gas Dryer
Frigidaire DG400EXF4 Wwh(v5) / Gas Dryer
Frigidaire DG400EXF5 Wwh(v6) / Gas Dryer
Frigidaire DG400EXH1 Wwh(v7) / Gas Dryer
Frigidaire DG400EXH4 Wwh(v8) / Gas Dryer
Frigidaire DG400EXH5 Wwh(v9) / Gas Dryer
Frigidaire DG400EXV1 Wwh(v10) / Gas Dryer
Frigidaire DG400EXV4 Wwh(v11) / Gas Dryer
Frigidaire DG400EXV5 Wwh(v12) / Gas Dryer
Frigidaire DG400EXW1 Wwh(v13) / Gas Dryer
Frigidaire DG400EXW4 Wwh(v14) / Gas Dryer
Frigidaire DG400EXW5 Wwh(v15) / Gas Dryer
Frigidaire DG400JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG400JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG400JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG400JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG400JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG400KXD1 Wwh(v9) / Gas Dryer
Frigidaire DG400KXD2 Wwh(v9) / 27 " Gas Dryer
Frigidaire DG400KXD3 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD4 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD5 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG400KXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXH1 Wwh(v8) / Gas Dryer
Frigidaire DG400KXH2 Wwh(v8) / 27 " Gas Dryer
Frigidaire DG400KXH3 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXH4 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXH5 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG400KXW1 Wwh(v7) / Gas Dryer
Frigidaire DG400KXW2 Wwh(v7) / 27 " Gas Dryer
Frigidaire DG400KXW3 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW4 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG400KXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG400SXD1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG400SXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXD0 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXD1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG400TXW0 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG400TXW1 Wwh(v2) / 27 " Gas Dryer
Maytag DG406 Dryer - Gas
Maytag DG407 Dryer - Gas
Maytag DG408 Dryer - Gas
Maytag DG409 Dryer - Gas
Maytag DG410 Dryer - Gas
Maytag DG412 Dryer - Gas
Maytag DG412D Dryer - Gas
Maytag DG482 Dryer - Gas
Maytag DG482D Dryer - Gas
Maytag DG490 Dryer - Gas
Maytag DG490D Dryer - Gas
Maytag DG4910 Dryer - Gas
Maytag DG500 Dryer - Gas
Frigidaire DG500AXD5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXW5 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500AXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500EXD1 Wwh(v16) / Gas Dryer
Frigidaire DG500EXD4 Wwh(v17) / Gas Dryer
Frigidaire DG500EXD5 Wwh(v18) / Gas Dryer
Frigidaire DG500EXF1 Wwh(v19) / Gas Dryer
Frigidaire DG500EXF4 Wwh(v20) / Gas Dryer
Frigidaire DG500EXF5 Wwh(v21) / Gas Dryer
Frigidaire DG500EXH1 Wwh(v22) / Gas Dryer
Frigidaire DG500EXH4 Wwh(v23) / Gas Dryer
Frigidaire DG500EXH5 Wwh(v24) / Gas Dryer
Frigidaire DG500EXV1 Wwh(v25) / Gas Dryer
  #2 (permalink)
Old 03-20-2013, 03:42 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The black o-ring goes first on the shaft, then the metal plate, then the coils.
Are sure you need the new coils?
What was the original problem and symptoms?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-20-2013, 07:57 PM
Junior Member
Default Maytag Gas Dryer Solenoid
My problem with the dryer was that it would go on normally and then after five minutes the flame would go off. In about 1 or 2 minutes after that, the igniter would glow red or orange, but the burner would not ignite and the igniter would turn off. I think it would glow and again the burner wouldn't ignite. The cycle would repeat itself. I looked online and based on the symptoms, it should be the solenoid. Does does make sense to you? Or could it be something else.
  #4 (permalink)
Old 03-21-2013, 10:38 AM
Expert
Default
Hi.
You are right, it's got to be the coils. But the cost wise you should consider replacing the hole gas valve assembly.
There is not such a big difference in price, but you'll get a brand new valve with coils new style.
Here are the breakdown diagrams and 05-Inlet Duct, Gas Valve, Cone & Ext. (01) parts for Maytag DG309 - AppliancePartsPros.com
Simon.
__________________
  #5 (permalink)
Old 03-21-2013, 10:59 AM
Junior Member
Default
I have another question. On the right shaft, that is attached to the gas valve assembly, I may have pulled on it a bit, thinking I could get if off. It seems to be attached to the assembly with a spring. It didn't come off, but my pulling did move it up maybe a 1/2" at the most. It sprung right back into place. Would this have damaged anything or affect the operation once I replace the solenoids?
  #6 (permalink)
Old 03-21-2013, 11:02 AM
Expert
Default
No, as long there is no gas leak.
Simon.
__________________
  #7 (permalink)
Old 03-21-2013, 11:04 AM
Junior Member
Default
Would I need to check for a gas leak after the solenoids have been replaced? Where do I check for the leak and how? Is it a matter of smelling for gas?
  #8 (permalink)
Old 03-21-2013, 12:35 PM
Expert
Default
Check around the shafts.You will smell the gas if it leaks.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Solenoid Replacement mrdonald Refrigerator & Freezer Repair 0 12-13-2011 08:00 PM
GE Drainage Solenoid Replacement tigerbothesh Dishwasher Repair 3 02-02-2011 12:51 AM
ice dispensor electronic board and solenoid burned out identically after replacement mrdaignault Refrigerator & Freezer Repair 8 07-23-2010 02:10 AM
solenoid replacement dhmosley Dishwasher Repair 0 05-12-2010 04:48 PM
Solenoid replacement unit Mrcashy Refrigerator & Freezer Repair 0 05-28-2009 01:08 PM
