| » Frigidaire FSG447GHS0 heats initially but only once |
Model Number: FSG447GHS0 Brand: Frigidaire Age: 5 - 10 years
Hello all. I have a FSG447GHS0 that doesn't dry clothes. Upon starting, the gas flows, the igniter glows, and I get a blue flame but it stays lit for only 6-7 min, and then switches off and will not light up again. I have tested the following parts using a digital multimeter:
Thermostat - This has 4 prongs. Two are close to each other and are arranged vertically. The resistance across them is 2.96 @ 20k. The other two are probably 3-4 times farther apart than the first two and are arranged horizontally. The resistance across them is 0.100 @ 2k. Igniter - 0.056 @ 2k. Flame sensor - I can't get a constant reading. The values range from 0.002 to 0.210 @ 2k. Solenoids - 2-pronged one: 1.347 @ 2k. 3-pronged one: Reading across prong #1 and #2 is 1.450 @ 2k; reading across prong #1 and #3 is 0.585 @ 2k. Ads By Google Related Models |
Hello,
If the igniter glows but there is no flame then the problem most likely is a bad gas valve coils. Even if they did pass the continuity test they can fail later under the heat stress. - The coil kit Part number: 5303931775 Here are the breakdown diagrams and Parts for Frigidaire FSG447GHS0 Dryer - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
The first number is the time stamp in the video: 0:20 After about 20 sec, ignitor flows and flame is nice a and blue + heat in the dryer. 4:20 Flame goes out 5:45 Lighter glows for about 10 sec and stops. No flame. 6:45 Lighter glows for about 10 sec and stops. No flame. 7:49 Lighter glows for about 10 sec and stops. No flame. 8:51 Lighter glows for about 10 sec and stops. No flame. 9:45 Lighter glows for about 10 sec and stops. No flame. 10:45 Lighter glows for about 10 sec and stops. No flame. ..... 19:20 Lighter glows for about 10 sec and stops. No flame. 20:15 Lighter glows for about 10 sec and stops. No flame. 21:40 Lighter glows for about 10 sec and stops. No flame. |
Quote:
__________________
| Display Modes | |
| frigidaire dryer heats, then gets too hot and stops | blove1329 | Dryer Repair | 0 | 09-29-2010 07:32 AM |
| dryer heats initially then heat turns off | cortinakyle | Dryer Repair | 0 | 03-23-2010 10:12 AM |
| Kenmore Elite H3 - Heats up initially but then stops heating. | anonymouscuban | Dryer Repair | 2 | 01-07-2010 07:52 PM |
| GE Gas Dryer heats initially and then goes cool | Greggy_D | Dryer Repair | 1 | 12-29-2009 11:43 AM |
| Heats up initially, then stops ... | Avenger9 | Dryer Repair | 1 | 07-17-2009 04:50 PM |
