Discuss
Dryer won't run
 in
Dryer Repair
Replaced Tfuse,checked switches voltages Now what to do Ads By Google Related Models Admiral  LNC7764A71  Dryer - Ele Admiral  LNC7764A77
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't run
  #1 (permalink)
Old 03-19-2013, 02:09 PM
Junior Member
Ronald Walls is on a distinguished road
Smile Dryer won't run
Model Number: LNC7764A71   Brand: Admiral   Age: More than 10 years
Ads By Google
Related Models
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
  #2 (permalink)
Old 03-19-2013, 05:54 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You need to check the door switch, the timer, wire harness and the motor.
Unplug the dryer.
Using the multimeter check continuity from C to NO at the door switch (door closed, one wire off the switch). If you read continuity - go to the next step. No continuity - replace the door switch.
Set the timer to TIME DRY. Contacts L-H, TM-N, L-M should have continuity.
Also the M-S when the timer knob is pushed in.
If the continuity tests out OK, check the wire harness to the motor and door switch.
Replace the motor.
Please post the serial number of the dryer.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
