Discuss
GE Prodigy won't start disconnected ground
 in
Dryer Repair
Hi all, I have a GE Profile Prodigy electric dryer that won't start. The screws holding the drum to the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Prodigy won't start disconnected ground
  #1 (permalink)
Old 03-16-2013, 04:14 PM
Junior Member
Babieca is on a distinguished road
Default GE Prodigy won't start disconnected ground
Brand: GE   Age: 5 - 10 years
Hi all,
The screws holding the drum to the bearing had stripped out so I just replaced them. I turned the dryer on and it ran great. opened the door to check that the drum was spinning and then it wouldn't turn on again.
I checked the timer switch, the door switch, thermal fuse, and start switch and they are all good.
Behind the switch panel there is a green ground wire that is connected to the panel with a screw the other end has a terminal clip but is not connected to anything. Is that what is causing the problem? I cannot see where it is supposed to clip to.
Any help would be greatly appreciated.
  #2 (permalink)
Old 04-06-2013, 01:04 PM
Junior Member
dryer dummy is on a distinguished road
Default
Do you have the wiring diagram that goes to the machine? I've had the spade connectors come loose after having the machine apart.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge prodigy washer verm Washer Repair 2 04-15-2010 05:04 PM
GE Prodigy with no heat rlharvey Dryer Repair 0 03-29-2010 04:14 PM
GE prodigy dryer won't turn on Schwalmhaus Dryer Repair 1 12-17-2009 02:17 AM
GE Prodigy Clothes Washer Frank Miller Washer Repair 0 01-02-2009 01:05 PM
