Discuss
Can't disconnect wires on thermal fuse
 in
Dryer Repair
Hello! Help would be so much appreciated! My 3 year old Roper by Whirlpool gas dryer suddenly stopped heating..It still
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Can't disconnect wires on thermal fuse
  #1 (permalink)
Old 03-14-2013, 08:35 AM
Junior Member
Claire0500 is on a distinguished road
Default Can't disconnect wires on thermal fuse
Brand: Roper   Age: 1 - 5 years
Hello! Help would be so much appreciated! My 3 year old Roper by Whirlpool gas dryer suddenly stopped heating..It still tumbles etc just no heat. We discovered there was a hole in the venting hose and lots of lent. After reading I think it must be the thermal fuse that is blown. We took off the back and tried to follow the directions for replacing it but have run into a problem. Everything talks like you can just take the 2 wires off by hand. These do not seem to just pull off. I can't figure out how to get them off. They are attached inside of a little metal thing. Do we need special pliers to pull off the metal things holding the wires? As you can tell I am NOT experienced at fixing things, but I can't afford a repairman right now. Thank you so much!
  #2 (permalink)
Old 03-15-2013, 02:30 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Part number: AP3132867
Above is a typical thermal fuse.
Yours may be different.
Cannot say as you din not include a model number.
As you can see it has male connectors.
The wires have female connectors that fit onto these.
Sometimes they are very tight.
Get a flat screw driver of the correct width.
Place it between the fuse body and the female connector bottom, then twist the screw driver forcing the connector up.
You may have to work back and forth (side to side) to get it high enough so it is loos.
Do not pull on the wires as you might pull the female connector off. It is just crimped to the wire.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer overheat blowing thermal fuse heater box, not vent fuse try2repairguy Dryer Repair 2 11-10-2011 08:27 AM
KitchenAid Oven Thermal Fuse Wires Shorted lostInIdaho Oven Repair (including Ranges and Cooktops) 4 09-14-2011 06:51 PM
order of purple and white fuse wires jjsmith Dishwasher Repair 1 12-06-2010 03:27 PM
Thermal fuse keeps blowing, burning on wires and circuit board _billc@pop.net Dishwasher Repair 1 02-20-2010 11:21 PM
Where is Thermal Fuse Please dpotts Dryer Repair 3 05-17-2009 05:09 PM
