Discuss
Element stays on all the time unless timer is "off"
 in
Dryer Repair
Replaced blown thermal cut off and blown thermal fuse. Checked continuity on operating thermostat and hi limit thermostat which were
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Element stays on all the time unless timer is "off"
  #1 (permalink)
Old 03-14-2013, 06:31 AM
Member
Nitro itch is on a distinguished road
Default Element stays on all the time unless timer is "off"
Model Number: Missing   Brand: Whirlpool   Age: More than 10 years
Replaced blown thermal cut off and blown thermal fuse. Checked continuity on operating thermostat and hi limit thermostat which were good. Checked ohm reading on element it was approx 10 ohms.
Dryer timer was ON with door opened when line power was turn ON via breaker, HOWEVER, element started to glow, obviously this was with no drum turning and no airflow due to door open. Next I closed the door allowing the air to flow.
With drum turning I checked amp draw with clamp on amp probe at one of the two element red leads and it was approx 27amps.
I DID NOT check continuity from element to frame for short circuit since the ohms read correct previously.
And if I remember correctly, when I checked voltage at element's two leads I got a reading of 124 volts, which I thought it should be 240ish....However, I don't remember at what point I checked this. Incoming power to dryer was 248 volts.
I did not have a schematic of this exact dryer until returning home. My thoughts are that the motor switch is supplying power on L2 ALL the time, and as long as the timer is ON thereby completeing the L1 circuit, the element stays ON. The dryer is located out of town, so I want to have solution and parts on hand when returning. Suspect: motor switch. Your thoughts and experience is appreciated.
Related Models
General Electric MK KIT 1 ICEMAKER
Whirlpool MK100
Whirlpool MK110
Jenn-Air MK241W MISC / ACCESSORY
Jenn-Air MK24B MISC / ACCESSORY
Jenn-Air MK271B MISC / ACCESSORY
Jenn-Air MK271W MISC / ACCESSORY
Jenn-Air MK272B MISC / ACCESSORY
Jenn-Air MK272W MISC / ACCESSORY
Jenn-Air MK27B MISC / ACCESSORY
Jenn-Air MK27W MISC / ACCESSORY
Jenn-Air MK301B MISC / ACCESSORY
Jenn-Air MK301W MISC / ACCESSORY
Jenn-Air MK302B MISC / ACCESSORY
Jenn-Air MK302W MISC / ACCESSORY
Jenn-Air MK30B MISC / ACCESSORY
Jenn-Air MK30W MISC / ACCESSORY
Amana ML-1 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-10 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-2 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-3 MWAVE - FAMILY SIZE (60 HZ)
KitchenAid ML-42082 DISHWASHER
KitchenAid ML-42117 DISHWASHER
KitchenAid ML-42131 HEAVY DUTY DISPOSER
KitchenAid ML-42132 HEAVY DUTY DISPOSER
KitchenAid ML-42135 HEAVY DUTY DISPOSER
KitchenAid ML-42136 HEAVY DUTY DISPOSER
Whirlpool ML02CCXHW REFRIGERATOR
Whirlpool ML02CCXHW1 REFRIGERATOR
Whirlpool ML03CCXHW REFRIGERATOR
Whirlpool ML03CCXHW1 REFRIGERATOR
Whirlpool ML05CCXHW REFRIGERATOR
Whirlpool ML05CCXHW1 REFRIGERATOR
Amana ML10 MWAVE- CNTRTP / STAND ALONE
Amana ML40 AMANA MWAVE- COUNTERTOP / STAN (MICROWAVE)
Amana ML441T MWAVE- CNTRTP / STAND ALONE
Amana ML446P AMANA MWAVE- COUNTERTOP / STAN (MICROWAVE)
Amana ML451T MWAVE- CNTRTP / STAND ALONE
Frigidaire MLCE52RCS0 Tap(v1) / Laundry Center
Frigidaire MLCE52RCS1 Frg(v1) / Laundry Center
Frigidaire MLCE52RCT0 Tap(v2) / Laundry Center
Frigidaire MLCE52RCT1 Frg(v2) / Laundry Center
Amana MLD510 COMMERCIAL MICROWAVES
Amana MLD510D COMMERCIAL MICROWAVES
Maytag MLE15MNAGW MANUAL, PARTS (DRYER GAS)
Maytag MLE15MNAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE15MNAZW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAUW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYA MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYQ MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAZW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDBGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE15PDCZW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PRAYW MANUAL, PARTS (DRYER GAS)
Maytag MLE15PRAZW MANUAL, PARTS (DRYER GAS)
Maytag MLE19PDAGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PDAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE19PDAZW MANUAL, PARTS (DRYER ELE)
Maytag MLE19PDCZQ MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PDCZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PDDGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PDDYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PNAUW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PNAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PNDYW COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MLE19PRAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PRAZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PRDYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE2000AYW STACKED LAUNDRY- ELE
Maytag MLE2000AZW STACKED LAUNDRY- ELE
Maytag MLE23MNAUW MANUAL, PARTS (DRYER ELE)
Maytag MLE23MNAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE23MNFYW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLE23PDAUW MAYTAG LAUNDRY MANUAL (DRYER ELE)
Maytag MLE23PDAYQ MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFGW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PDFUW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PRAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PRFYW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PRFZW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE24PDAGW0 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PDAYW1 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PDAZW0 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PDAZW1 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PNAGW0 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PRAYW1 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PRAZW0 COMMERCIAL ELECTRIC DRYER
Frigidaire MLF303PGDA Frg(v1) / Gas Range
Frigidaire MLF303PGDC Frg(v1) / Gas Range
Frigidaire MLF303PGDD Frg(v2) / Gas Range
Frigidaire MLF303PGWA Frg(v2) / Gas Range
Frigidaire MLF303PGWC Frg(v3) / Gas Range
Frigidaire MLF303PGWD Frg(v4) / Gas Range
Frigidaire MLF311SGDA Frg(v1) / Gas Range
Frigidaire MLF311SGDC Frg(v1) / Gas Range
Frigidaire MLF311SGDD Frg(v1) / Gas Range
Frigidaire MLF311SGWA Frg(v2) / Gas Range
Frigidaire MLF311SGWC Frg(v2) / Gas Range
Frigidaire MLF311SGWD Frg(v2) / Gas Range
Maytag MLG15MNAEW MANUAL, PARTS (DRYER GAS)
Maytag MLG15MNAGW MANUAL, PARTS (DRYER GAS)
Maytag MLG15MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAEW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLG15PDAWA MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAWQ MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAXA MANUAL, PARTS (DRYER GAS)
  #2 (permalink)
Old 03-14-2013, 08:14 AM
Member
Default
Sorry no model number avail...but this is the typical WP dryer design of 20 plus yrs.
  #3 (permalink)
Old 03-16-2013, 03:51 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
You should check for a grounded element.
It may be touching the case/frame but is not broken.
In this case it would read the correct resistance across the coil but still always be on because it is grounded.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool model GMC305PDB07 light stays on and has "door" message on display Luda Oven Repair (including Ranges and Cooktops) 1 07-11-2014 05:16 PM
"element on" light stays on Flannthered Oven Repair (including Ranges and Cooktops) 0 01-07-2013 05:19 PM
Electric Range Short Circuits, "Element On" display light stays on (so do elements) Mr. Meister Oven Repair (including Ranges and Cooktops) 0 05-31-2012 12:21 PM
"Element on" indicator stays on Flannthered Oven Repair (including Ranges and Cooktops) 2 05-20-2011 09:33 PM
Whirlpool model GMC305PDB07 light stays on and has "door" message on display Luda Oven Repair (including Ranges and Cooktops) 1 08-06-2010 01:06 PM
