Discuss
Dryer won't turn on the motor or heating element
 in
Dryer Repair
My gas dryer has stopped working! The motor won't turn and the heating element produces no heat to ignite the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't turn on the motor or heating element
  #1 (permalink)
Old 03-13-2013, 07:03 PM
Junior Member
axnst1 is on a distinguished road
Question Dryer won't turn on the motor or heating element
Model Number: LGQ8000JQ5   Brand: Whirlpool   Age: 5 - 10 years
My gas dryer has stopped working! The motor won't turn and the heating element produces no heat to ignite the gas! Other than the timer ticking, the dryer makes no sound! I don't hear the motor turning or the gas kicking on! So I ripped the dryer apart and here's what I found:
- door switch works
- start button works and when turned on I get 120V going across it!
- I get no conductivity accross any connectors on the back of the Wrinkle Shield nobe (though I don't think this would matter)
- I get conductivity across all of the thermocouples
- timer ticks and I get 120 Volts between tan wire (back of timer) and a - bunch of different other wires (back of timer) (blue for example)
- thermo fuse replaced (I was hoping it was this so I replaced it first), works
- belt not broken
if I unplug the connector from the drive motor switch I get 120V across two wires (can't remember which two but I will check again)
However, I get no voltage going from (I think) the drive motor switch to the motor! On the picture below I get no voltage across the two wires in the back of the motor switch (marked with red arrows):
my gas dryer's drive motor switch - YouTube
So questions:
- Does this sound like my drive motor switch is bad?
- Should the ignitor still start to heat up?
- Could it still be my timer?
- If there is something wrong with the high limit switch or the ignitor or any of the gas valves, shouldn't my motor still start spinning? Meaning is it possible that my motor isn't starting because one of the above itmes have gone bad? I would think it'd be the other way around, no? Meaning if the motor doesn't start = no heating initiated! So basically which relies on which to start first?
Thanks! Any help would be great!
Related Models
Whirlpool LGQ8000JQ5 29"GAS DRYER
Whirlpool LGQ8100KQ0 RESIDENTIAL DRYER
Whirlpool LGQ8100KQ1 RESIDENTIAL DRYER
Whirlpool LGQ8100KT0 RESIDENTIAL DRYER
Whirlpool LGQ8100KT1 RESIDENTIAL DRYER
Whirlpool LGQ8611LG0 RESIDENTIAL DRYER
Whirlpool LGQ8611LG1 27"GAS DRYER
Whirlpool LGQ8611LW0 RESIDENTIAL DRYER
Whirlpool LGQ8611LW1 27"GAS DRYER
Whirlpool LGQ8611PG0 27"GAS DRYER
Whirlpool LGQ8611PG1 27"GAS DRYER
Whirlpool LGQ8611PG2 27"GAS DRYER
Whirlpool LGQ8611PG3 27"GAS DRYER
Whirlpool LGQ8611PW0 27"GAS DRYER
Whirlpool LGQ8611PW1 27"GAS DRYER
Whirlpool LGQ8611PW2 27"GAS DRYER
Whirlpool LGQ8611PW3 27"GAS DRYER
Whirlpool LGQ8621PG0 27" GAS DRYER
Whirlpool LGQ8621PG1 27" GAS DRYER
Whirlpool LGQ8621PG2 27" GAS DRYER
Whirlpool LGQ8621PG3 27" GAS DRYER
Whirlpool LGQ8621PW0 27" GAS DRYER
Whirlpool LGQ8621PW1 27" GAS DRYER
Whirlpool LGQ8621PW2 27" GAS DRYER
Whirlpool LGQ8621PW3 27" GAS DRYER
Whirlpool LGQ8800JQ0 GAS DRYER
Whirlpool LGQ8800JQ1 DRYER
Whirlpool LGQ8800JQ2 DRYER
Whirlpool LGQ8800JT0 GAS DRYER
Whirlpool LGQ8800JT1 DRYER
Whirlpool LGQ8800JT2 DRYER
Whirlpool LGQ8857HQ0 DRYER
Whirlpool LGQ8857HQ1 GAS DRYER
Whirlpool LGQ8857HZ0 DRYER
Whirlpool LGQ8857HZ1 GAS DRYER
Whirlpool LGQ8857JQ0 GAS DRYER
Whirlpool LGQ8857JQ1 DRYER
Whirlpool LGQ8857JQ2 DRYER
Whirlpool LGQ8857JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8857JT0 GAS DRYER
Whirlpool LGQ8857JT1 DRYER
Whirlpool LGQ8857JT2 DRYER
Whirlpool LGQ8857JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858HQ0 GAS DRYER
Whirlpool LGQ8858HQ1 GAS DRYER
Whirlpool LGQ8858HZ0 GAS DRYER
Whirlpool LGQ8858HZ1 GAS DRYER
Whirlpool LGQ8858JQ0 GAS DRYER
Whirlpool LGQ8858JQ1 DRYER
Whirlpool LGQ8858JQ2 DRYER
Whirlpool LGQ8858JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8858JT0 GAS DRYER
Whirlpool LGQ8858JT1 DRYER
Whirlpool LGQ8858JT2 DRYER
Whirlpool LGQ8858JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858JZ0 GAS DRYER
Whirlpool LGQ8858JZ1 DRYER
Whirlpool LGQ8858JZ2 DRYER
Whirlpool LGQ9030PQ0 29"GAS DRYER
Whirlpool LGQ9030PQ1 29"GAS DRYER
Whirlpool LGQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9508KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9508LG0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW1 29"GAS DRYER
Whirlpool LGQ9508PG0 29"GAS DRYER
Whirlpool LGQ9508PG1 29"GAS DRYER
Whirlpool LGQ9508PW0 29"GAS DRYER
Whirlpool LGQ9508PW1 29"GAS DRYER
Whirlpool LGQ9557KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9557KT0 RESIDENTIAL DRYER
Whirlpool LGQ9557KT1 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9558KT0 RESIDENTIAL DRYER
Whirlpool LGQ9558KT1 RESIDENTIAL DRYER
Whirlpool LGQ9857LG0 RESIDENTIAL DRYER
Whirlpool LGQ9857LG1 29"GAS DRYER
Whirlpool LGQ9857LW0 RESIDENTIAL DRYER
Whirlpool LGQ9857LW1 29"GAS DRYER
Whirlpool LGQ9857PW0 29"GAS DRYER
Whirlpool LGQ9858LG0 RESIDENTIAL DRYER
Whirlpool LGQ9858LG1 29"GAS DRYER
Whirlpool LGQ9858LW0 RESIDENTIAL DRYER
Whirlpool LGQ9858LW1 29"GAS DRYER
Whirlpool LGQ9858PG0 29"GAS DRYER
Whirlpool LGQ9858PG1 29"GAS DRYER
Whirlpool LGQ9858PW0 29"GAS DRYER
Whirlpool LGQ9858PW1 29"GAS DRYER
Whirlpool LGR2614BW0 GAS DRYER
Whirlpool LGR2614BW1 GAS DRYER
Whirlpool LGR2614BW2 GAS DRYER
Whirlpool LGR2614DW0 GAS DRYER
Whirlpool LGR2614DW1 GAS DRYER
Whirlpool LGR2614EW0 GAS DRYER
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB RANGE- S/C F/S GAS
Admiral LGR3330ADW RANGE- S/C F/S GAS
Admiral LGR3330ADZ RANGE- S/C F/S GAS
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0 Residential Dryer
Whirlpool LGR3424AW0 Residential Dryer
Whirlpool LGR3622BN0 COMPACT GAS DRYER
Whirlpool LGR3622BW0 COMPACT GAS DRYER
Whirlpool LGR3622DQ1 COMPACT GAS DRYER
Whirlpool LGR3622DZ1 COMPACT GAS DRYER
Whirlpool LGR3624BN2 GAS DRYER
Whirlpool LGR3624BW0 GAS DRYER
Whirlpool LGR3624BW1 GAS DRYER
Whirlpool LGR3624BW2 GAS DRYER
Whirlpool LGR3624DQ1 GAS DRYER
Whirlpool LGR3624EQ0 GAS DRYER
Whirlpool LGR3624EQ1 GAS DRYER
Whirlpool LGR3624EQ2 GAS DRYER
Whirlpool LGR3624JQ0 GAS DRYER
Whirlpool LGR3624JQ1 RESIDENTIAL DRYER
Whirlpool LGR3624JQ2 29" GAS DRYER
Whirlpool LGR3624JQ3 29" GAS DRYER
Whirlpool LGR3624PQ0 29" GAS DRYER
  #2 (permalink)
Old 03-14-2013, 05:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by axnst1 View Post
...On the picture below I get no voltage across the two wires in the back of the motor switch (marked with red arrows)...
Can you describe how did you do this test please?
The heating part of the dryer should not work if the motor does not.
Here are the breakdown diagrams and Parts for Whirlpool LGQ8000JQ5 Dryer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heating Element On Before Motor Spins Sh00tnBlanks Dryer Repair 5 10-19-2012 06:19 AM
Frigidaire Dishwasher heating element won't turn off! tjoy1971 Dishwasher Repair 0 03-21-2010 03:00 PM
Heating element wont turn off hillbilly34207 Dryer Repair 1 01-11-2010 04:42 PM
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
Whirlpool Oven Upper Heating Element won't turn off ilfang Oven Repair (including Ranges and Cooktops) 1 01-18-2009 07:41 PM
